FCP SD 16:9 Multiclip problems
Mitch Stivason
on Nov 4, 2011 at 4:36:22 am
Sorry in advance for the long post but this is driving me crazy.
My Setup:
3 Camera Shot with 2 Panasonic SDR-S26 and 1 Panasonic SDR-H80
SD camera's setup in 16:9 format
The only difference between them i believe is one records to an internal HD and the 2 record to SD cards.
Zoom H4n to record audio
2011 iMac i7 12GB mem, 2GB video RAM, SSD + 2TB HD
I'm using FCS 6.0.6
I copied the .mod files to my system SSD, used mpeg stream clip to convert them several different times.
Here's what I've tried all transcoded to my internal 2TB HDD:
Apple Pro Res 422 left frame size 854x480
Apple Intermediate Codec Same Frame size
Apple DV/DVC Pro
I even found this page and tried what it suggested:
http://imnotbruce.blogspot.com/2011/08/converting-mod-files-for-final-cut-p...
using export to DV25 leaving 16:9 deinterlace (doing it this way I had to render my audio in FCP for some reason)
For all formats I import the respective videos into a sequence with my H4n audio. Use Pluraleyes to since them up, export the quicktime movie reference files, use plural eyes to create the multiclip, bring it in a new sequence w/ the audio, set play heads to open and try to edit. However when I try to RT edit the viewer doesn't RT move and when I switch angles it all just stops and doesn't make the edit cuts.
Any help would be so much appreciated.
Mitch
