AVC Intra VFR Import in FCP
Markus Knapp
on Nov 2, 2011 at 10:58:54 am
Hello,
I recently bought the Panasonic HPX250 and now I'm figuring out the workflow for cutting.
I import the AVC Intra as ProRes Proxy.
Now I've got some shot with variable frame rate (6p/50i). Importing this in FCP with the option to delete duplicate frames gives me a clip in 50i which is still running in "realtime" and not with the right speedup.
How do I import variable frame rate material into Final Cut Pro 7?
Thx for you help.
Markus
Jeremy Garchow
Re: AVC Intra VFR Import in FCP
on Nov 3, 2011 at 12:08:04 am
VFR works in 720p mode. Give that a shot (pun intended)
Markus Knapp
on Nov 3, 2011 at 10:56:43 am
Thx. I'll try that.
VFR in 50i seems to be a new feature of the Panasonic HPX250.
Jeremy Garchow
on Nov 3, 2011 at 1:41:01 pm
Maybe VFR works in 1080p like AF 100. If so, your clips should come in already conformed, no slo motion necessary (at 25p, not 50i).
Markus Knapp
on Nov 6, 2011 at 8:46:09 pm
You are right. VFR only works in 1080pn25 or 720pn25.
In 1080i50 or 720p50 VFR has a different effect. In the manual, it's called "flow effect shot".
Thanks anyway.
