Slip Tool problems
Robert Paige
Slip Tool problems
on Nov 1, 2011 at 11:47:59 pm
I been having problems recently with the Slip Tool.
For some reason when I use it on the clip, the first frame of that clip doesn't match the left window of the 2 window display, when the slip tool is used. It shows a different time of the clip when changed and doesn't match. I've never had this problem before but I believe it might be a setting or some sort of preference that has been changed.
Jerry Hofmann
Re: Slip Tool problems
on Nov 2, 2011 at 2:08:52 pm
You're unclear here. Explain the problem a different way. There is no settings BTW that affect the slip or slide tools...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
