Clips looks low res when droped in to a sequence
yamir bhatt
on Oct 30, 2011 at 2:31:12 pm
So I am new to FCP. I have been working mostly in AE. I am trying to edit a small interview and the clips looks fine when i double click it. But once I bring it in a sequene and edit it, it looks low res. I looked in the RT setting and that is set to Highres in playback and frame rate, where else can I look to improve the clip quality?
Brad Wright
Re: Clips looks low res when droped in to a sequence
on Oct 30, 2011 at 4:10:16 pm
Take a look at your sequence settings. The default video options may be DV for FCP and therefore it's resizing the video to standard definition.
Brad Wright is software engineer, so often hard to figure out what he is talking about. He is always happy to explain answers further.
Rafael Amador
on Oct 30, 2011 at 4:21:48 pm
Please Yamir, a bit more of info about the footage and sequence settings.
rafael
http://www.nagavideo.com
yamir bhatt
on Oct 31, 2011 at 12:09:41 am
it was sequence setting. Missed it the first time i looked in to it
Sequence>Setting>render control> Render>...
Buya!!
Thanks All
Steve Eisen
on Oct 30, 2011 at 5:14:05 pm
To add to the above comments, you can not judge the quality from your computer monitor.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Brad Wright
on Oct 30, 2011 at 10:20:16 pm
Yes, I second that. Never use your computer monitor to color correct video footage. Always use HD-SDI or firewire out to a calibrated television monitor.
David Roth Weiss
on Oct 30, 2011 at 10:22:56 pm
[Brad Wright] "Never use your computer monitor to color correct video footage. Always use HD-SDI or firewire out to a calibrated television monitor."
I think you forget one Brad - what happened to component out to a calibrated monitor?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
yamir bhatt
on Oct 30, 2011 at 11:28:30 pm
so this is the problem
the clip on left and the same clip dropped in the sequence on the right. the sequence settings are the same as the clips settings prores 4444 720x480. All i did was drop the clip in a new sequence... how do i fix this?
Rafael Amador
on Oct 31, 2011 at 3:17:30 am
To Start, set the canvas window at 100% and have a look again.
rafael
