More than 4 multi cam angles won't show up at the same time?
Peter Vandall
on Oct 28, 2011 at 12:41:53 pm
Hi I am working on a shoot with 5 camera angles. Only 4 show up, and if I want to see the 5th, I have to stop Final Cut and click an arrow in the lower right hand corner of the viewer, select the angle, and hit play again.
What gives? Is there a way to display more than 4 angles simultaneously?
Thank you!
Peter
Alex Elkins
Re: More than 4 multi cam angles won't show up at the same time?
on Oct 28, 2011 at 2:16:09 pm
Hi Peter
When you have a multiclip loaded in the viewer, click on the wireframe icon and select 'Multiclip 9-Up'. you will see each angle.
Alex Elkins
Twitter: @postbluetv
http://www.PostBlue.tv
View Post Blue showreel
Shot on RED @ 100fps, Post on FCP/Color: Capoeira Film
