Final Cut Effects
Praveen Nu
Final Cut Effects
on Oct 28, 2011 at 4:20:54 am
Hi All,
I have created a Final Cut Effects in Motion and its working fine. My .moef file has a duration of 300 frames. If i apply it to a 600frame clip, its stretching and i want to avoid that. Either i can loop it twice or i can select first 300 frame and apply it to that selection only. Pls give me a solution to achieve this.One more thing is there a way to offset the effects in FCP?
Thank you,
Praveen N U
Praveen Nu
Re: Final Cut Effects
on Oct 28, 2011 at 11:18:39 am
Offset means .. the clip has 600 frames duration and i want the effect to start after 100 frame. Is that possible with out splitting the layer by putting a marker or something?..
