syncing 3 tracks of audio with clapper board.
viking jonsson
on Oct 27, 2011 at 5:05:02 pm
Hello,
I'm currently working as an assistant editor at a short film. We have been using three microphones.
The timecode dosen't work so I sync by clapperboard. When I try to Merge Clips at in points the tracks are 1-3 frames off sync cause of the clapper sounding at different times in the microphones..
What to do?
Any tips?
Thank You
Viking
Miriam Lefkowitz
Re: syncing 3 tracks of audio with clapper board.
on Oct 27, 2011 at 9:28:03 pm
Select one audio clip, hold the option key, & move audio track one frame at a time with the left and right arrows. I always pick a part of the audio with a clipped sound to check if they are synced.
If the audio tracks cannot sync because of the different microphone placements, you can do a sub-frame audio edit. zoom into timeline so you can see the whole frame. click on the track so it is in the viewer. Shift-click on the viewer playhead and you can drag the track. Release the mouse and shift key.
This is from tutorial by Shane Ross, off of this thread:
http://forums.creativecow.net/thread/8/997154
Miriam Lefkowitz
on Oct 27, 2011 at 10:31:11 pm
sorry, forgot to say click I (In) when you release the mouse and this will move the frame.
also, the video
http://proappstuff.com/proapptipsvideotutorials/879F6B61-CFF9-4FD1-8D43-FDF...
is by Capt. Mench (?).
viking jonsson
on Oct 29, 2011 at 9:21:00 am
thank you!
I actually worked my way around it :)
