XDCAM Transfer Tool Audio Issue
Andrew Wood
on Oct 26, 2011 at 6:42:15 pm
This past week I've been using the XDCAM Transfer Tool in FCP7. The footage is running off off a LACIE external. I had transferred some clips fine the last two days then suddenly now when I use the XDCAM Transfer Tool the clip I import the audio is all off a very glitchy (up and down in levels). Now I tried with a previous clip I had captured before alright and the same situation is happening now to all the material on the external. However if I preview in the transfer tool playback it appears to be fine, but once imported into FCP if just in the browser or putting it down on a sequence the audio is a mess.
