Flix Pro Video Dimension Problem
Grant Peacock
on Oct 23, 2011 at 1:10:54 pm
I have a PAL 16:9 clip exported out of Final Cut Pro. It needs to be converted to .flv format.
No matter what settings I used in Flix Pro's video window for 'Output video dimensions' the output is always squeezed back into an approximate 4:3 aspect. (Available Flix Pro adjustments are : Use Source Dimensions on/off, No constraints on/off, Maintain source aspect ratios on/off)
What am I missing? I can't find any other settings to adjust.
Rafael Amador
Re: Flix Pro Video Dimension Problem
on Oct 23, 2011 at 3:23:30 pm
[Grant Peacock] "What am I missing? I can't find any other settings to adjust."
That your 720x576 pixels are PAL Anamorphic, and what you need to display that properly in a web are Square pixels.
Rescale that to 1024x576. Deinterlace before.
rafel
http://www.nagavideo.com
