Only brings one audio track into timeline, and doesn't play it!
Joel Kling
on Oct 22, 2011 at 9:59:19 pm
I hit some setting on accident, and now when I bring a clip into the timeline it only brings one audio track (a2) and doesn't even play that track back when viewed. Does anyone know what I may have changed in the settings and how to revert, or undo this setting. For the life of me, I don't know why this setting would even exist!
Thank you!
Michael Gissing
Re: Only brings one audio track into timeline, and doesn't play it!
on Oct 22, 2011 at 11:36:46 pm
The setting exists for those times when you only want to bring in one of many tracks of audio into an edit or even to swap left and right. Quick and easy way is to right click in the tracks area and select 'reset panel'.
I recommend reading the manual about how to set audio tracks and enable/ disable at will source to destination audio that you will need in the future.
Joel Kling
on Oct 24, 2011 at 6:53:09 pm
