HDV .mov files won't play on FCP and QuickTime
Maurice Coombs
on Oct 22, 2011 at 1:08:33 am
I applied and update to my MacBook pro and BAM!! Now my HDV.mov files won't play with QuickTime or final cut pro. I'm in the middle of a project and I can't finish it because when the files play in fcp I get a error. Can anybody help me with this.
Phil Balsdon
Re: HDV .mov files won't play on FCP and QuickTime
on Oct 22, 2011 at 12:20:33 pm
It's iTunes 10.5 update that's caused it. Working on a cloned boot drive myself to get an urgent job for a new client completed by Monday.
Then I'll do my third complete system re-install this year. Last one was when QT 7.7 did the same thing a couple of months back.
Can't run a professional business like this. Seriously considering buying Adobe Production Suite before the end of the week to get the SWITCH bonus.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://philming.com.au
http://www.steadi-onfilms.com.au/
Maurice Coombs
on Oct 22, 2011 at 12:42:00 pm
Is there anyway of just uninstalling iTunes that might fix the problem without doing a complete system reinstall?
Phil Balsdon
on Oct 22, 2011 at 2:13:30 pm
I tried uninstalling iTunes with MacKeeper, then re-installing version 9.? from my 10.6 install disc. Then downloaded and installed iTunes 10.3. This didn't fix the problem with the HDV files.
VLC is the only app I've got that will open them.
Maurice Coombs
on Oct 22, 2011 at 2:19:43 pm
Thanks, I was able to down load a third party converter from the mac app store that was able to convert the files to what ever i needed. I guess I will just have to convert all my video over to a different format.
Thanks again.
Phil Balsdon
on Oct 22, 2011 at 2:45:51 pm
What was the app called?
Maurice Coombs
on Oct 22, 2011 at 3:03:00 pm
It's called HD Video Converter. It can convert whatever video into fcp codecs which is great!
Phil Balsdon
on Oct 23, 2011 at 12:13:30 am
I downloaded the trial version of HD Converter.
It certainly works. The downside is this means archiving everything as Apple ProRes (fortunately I can use ProRes LT) which takes up extra hard drive space, also it's fairly slow.
Next experiment is to record as m2t files on my Firestore and see if Clipwrap fixes it.
Maurice Coombs
on Oct 23, 2011 at 12:30:11 am
I converted my video to h.264 at the highest bit rate and the files look great. I know it's a compressed codec but the amount of space I save I'd great. I'll live with it. Apple ProRes is to big of a file. 264 works for me and FCP can use it with no rendering. Try it out and let me know what u think.
Phil Balsdon
on Oct 23, 2011 at 2:19:29 am
Want to keep the most original format I can as an archive. H264 doesn't work well in FCP 7.
Everything I edit is my footage so for the HDV files I need something to convert them (or re-install the OS10.6.8 and lock the computer, which is what I'm intending to do).
However I do shoot with the JVC HD111E for other clients who use FCP 7 and 6 in post. This is the issue I need to work around, although the main one has just emailed me telling me he's had enough, bought Adobe Production Suite with the 50% SWITCH offer and will move over during the slow period around Xmas.
Christopher McDonell
on Oct 23, 2011 at 5:00:19 am
[Phil Balsdon] "It's iTunes 10.5 update that's caused it."
Why don't I have this problem?
Phil Balsdon
on Oct 23, 2011 at 6:03:18 am
For me these are Quicktime HDV files recorded on an onboard Firestore DR-100 on a JVC HD111E. I know this happening to other people but unsure of their formats from looking at the forum here and Apple. Last time it happened was with the Quicktime 7.7 update in August. I didn't realise iTunes would do the same thing when I let it manually update last week.
The only way to properly sort it is with a system re-install. I'd disconnect the computer from the internet completely and do no more updates if I wasn't using it for web work with the video. Anyway lesson learnt and I was able to finish an edit using a backed up system drive.
However this is going to present problems with my laptop, which I use on location to transfer the files for clients and syncing my iPhone etc. With all further progress in FCS development halted by Apple, it's time for a rethink about the future. FCP eX isn't sufficient for me so I'll probably change to Adobe Production, seeing as whatever I do (even FCP eX) means learning a new system anyway and that's the way most clients I shoot for are going.
Maurice Coombs
on Oct 23, 2011 at 3:54:37 pm
I wanted to thank everybody for there input, If i want to fix my problem i'm just going to have to do a system reinstall which sucks because i dont have all the disks. I do have CS4 and I know premiere pro very well so for now I'll just start shooting im M2T.
thanks
Phil Balsdon
on Oct 23, 2011 at 8:31:59 pm
Clipwrap will re-wrap m2t files as .mov which work fine. It won't open the previous .mov files recorded on the Firestore though.
This is weird because it''s not converting them, just re-wrapping. I've been using the Quicktimes direct from the Firestore for years without a hitch and none of the previously good files will play any more. The re-wrap process is very fast too.
Clipwrap 2 will also convert the m2t files to ProRes.
Phil Balsdon
on Oct 23, 2011 at 9:10:49 pm
Found a fix. This solved the issue down loading and re-installing Quicktime 7.5.5
http://www.digitalrebellion.com/blog/posts/using_pacifist_to_downgrade_quic...
I'd create a backup of the System / Components and Quicktime folders first though, just incase you need to revert back.
Maurice Coombs
on Oct 23, 2011 at 10:16:41 pm
Thanks so much for this tip. I am going to try this out. Best news I got all day after watching my dolphins lose a 15 point lead to tebow in the the last 3min of the game. Thanks for taking the time to help me out!
Guy Volb
on Oct 23, 2011 at 3:49:55 pm
I have a similar issue: HDV clips previously captured via FCP 7 on my MacBook Pro now fail to sync audio wise when in the editing mode. I.E. import your clips, render etc and then try to play them in the FCP canvas window and the audio doesn't sync. This began after I bought the newest MacBook Pro using Lion and updated all the relevant software. FCP 7 remained the same of course. Anyway, it takes a run through once or twice before the audio catches up. Extremely frustrating. With regards to Quick Time play, these clips play but with a horrible echo. Again, if played through and then replayed, the echo disappears. Very odd!! As a multi-media guy, this challenges my workflow and my sanity.
If this is an iTunes related issue, I surely hope Apple figures it out quickly.
At this point I'm beginning to wish I didn't "upgrade" and used my $3K for another pro investment.
As an aside, VLC plays them just fine -- which is scary given that it tells me third party software works better on my MacBook Pro than in-house developed software. Works fine with Soundtrack Pro as well (no echo or audio syn issues with the video). Very odd!
Joy Endicott
on Dec 10, 2011 at 2:11:08 am
Our broken HDV files were originally recorded using
Digital Recorder: Focus Enhancement DTE FireStore FS--4 Pro HD, Version 2.0.0.04092006 NTSC
Format: Quicktime, external timecode, in Syncro Slave mode
Camera: Sony Z1U
Format: 1440 x 1080i, to internal HDV tape and via firewire to FS-4
Through a lengthy discussion with Apple, they directed me back to
http://www.focusinfo.com/dynassets/documents/downloads/MACOSX_Supp_Anncmt_1...
and suggested that I do e-mail the support@focusinfo.com.
Focus quickly sent
HDFileConverterUpdater_v1.2.dmg
and a document explaining the bug and the fix.
This worked perfectly! No downloading of pacifist, no searching for and deleting components and QT libraries, no downgrading needed.
stu aull
on Nov 27, 2013 at 5:46:59 pm
My solution - as found via APPLE FORUMS:
Background:
OS 10.6.8/FCP7.0.3
I was prepping to update to Mtn Lion and was advised to first do a Software Update of current OS.
Mistake! HDVs now invisible (green screen in FCP, QT would not play video portion)
The Update also updated the QT HDV CODEC to one which is, apparently, broken!!
Solution:
In my case I had a cloned (and non-updated!) OS from which I just grabbed the
LIBRARY>QUICKTIME>AppleHDVCodec and dropped it into the NEW OS (after discarding its version)
BOOM!
fixed.
If you have no clone then pull off your original install OS disc.
FWIW My "working" Codec is v2.0.
