Moray effect
Jonny Cates
Moray effect
on Oct 21, 2011 at 10:38:31 pm
I don't know how to correct for this problem, or why exactly it's happening- but I have a short motion effect (done in the motion tab in FCP) of a high school yearbook making a zig-zag path toward the viewer. It gets bigger and bigger, and then stops and slides to the right. But what am I doing wrong to get this moray effect when the book is tilted and moving? It only happens when the image is tilted. It looks fine when it moves to the left or right, up or down with no angle added to it. it's also a .png file....about 150 dpi.
Thanks to any response....
Jonny Cates
Michael Gissing
Re: Moray effect
on Oct 21, 2011 at 10:41:26 pm
Hi res stills can moire with movement. 72 dpi is effectively video res. Try a bit of Gaussian blur.
Jonny Cates
Re: Moray effect
on Oct 22, 2011 at 12:35:05 am
Thanks Mike...that seemed to help!
Jonny Cates
Rafael Amador
Re: Moray effect
on Oct 22, 2011 at 9:14:22 am
And set "Render Motion Effects: BEST", in your sequence settings.
rafael
http://www.nagavideo.com
