Overlay 2 moving objects 100% opacity
Daniel Heinsohn
on Oct 21, 2011 at 1:08:32 pm
Hello, i'm trying to overlay the same clip wich has a moving object, but i would like that the 2 objects have 100% opacity and only one background stays in the screen. ┬┐is that possible?
Greetings
Jerry Hofmann
Re: Overlay 2 moving objects 100% opacity
on Oct 21, 2011 at 3:40:05 pm
Well, you'd have to cut out the moving object frame by frame with a matte. Rotoscoping it's called.
What are you trying to achieve in the end? what's the effect you're after?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
