Different Frame rates Need solutions
Elie Mosseri
on Oct 20, 2011 at 10:42:40 pm
I am editing a project Prores 23.98 1920 X 1080 majority of footage shot XDCAM EX 23.98. Additional footage shot on same camera only at 29.97 frame size 1440X1080 and Pixel size HD 1440 X 1080. The 29.97 is not working well on the timeline very jittery. I have tried exporting the files and making them Prores 23.98 and then dropping them back into the timeline but I am still getting jittery footage. I could really use a solution for this if one does exists. Working on FCP.
Elie
Eric Strand
Re: Different Frame rates Need solutions
on Oct 21, 2011 at 1:06:09 am
Try conforming them in Cinema Tools. http://www.wonderhowto.com/how-to-batch-conform-video-clips-with-apples-cin...
Elie Mosseri
on Oct 21, 2011 at 2:01:20 am
I tried that and it looks great the only issue is that it slows the video down and with that it slows the audio down. Making the clip out of sync. I need the video and audio to work at normal speed. How do you prevent that from happening?
Eric Strand
on Oct 21, 2011 at 2:24:25 am
True true, forgot about that. Drop your clips into compressor, change the frame rate to 23.98 in Video Settings, then in the frame controls tab turn Rate Conversion to Better.
