SD Video and Stills for Web: FCP Optimum Sequence Settings and Codec?
Lawrence Richards
on Oct 19, 2011 at 8:15:31 am
Hello All,
I've been searching in the forums and just not able to find this information so any help is appreciated.
I have a bunch of SD video and stills I need to put together for web-based only video. What is the optimum sequence and codec settings?
Thank you!!!
Larry
Thank you!
Larry R.
Florida
Chris Tompkins
Re: SD Video and Stills for Web: FCP Optimum Sequence Settings and Codec?
on Oct 19, 2011 at 11:37:51 am
Start with easy setup dv ntsc 29.97
Is your SD material Mini DV?
When the edit is done and complete, change your sequence settings to 8 bit uncompressed and re-render fully.
Then, export quicktime using "Current Settings"
Take that file into your compression program to create the deliverables.
Chris Tompkins
Video Atlanta LLC
Rafael Amador
on Oct 20, 2011 at 2:01:40 am
[Lawrence Richards] "I've been searching in the forums and just not able to find this information so any help is appreciated.
I have a bunch of SD video and stills I need to put together for web-based only video. What is the optimum sequence and codec settings?"
There are not best settings.
That will depends on the resolution you wan't for the web video and the data-rate you can allow the clip.
The codec: H264.
Fallow Chris advice.
rafael
http://www.nagavideo.com
