interlace video lines?
Dave Skinner
on Oct 17, 2011 at 5:50:06 am
Hi, I just cut up a wedding video. It was shot with an EX3 at 1080 25p.
I've exported it and now there are (not sure what to call them) lines all over the image when there is a camera move. i've left a screenshot below.
I've exported it in Prores 422.
Can anybody help me with getting rid of the lines?
Thanks.
3082_screenshot20111017at6.34.19pm.png.zip
Jeff Meyer
Re: interlace video lines?
on Oct 17, 2011 at 6:05:41 am
What are your sequence settings?
Michael Gissing
on Oct 17, 2011 at 6:52:37 am
Interlaced video on a progressive computer monitor will show interlace lines. This is normal. Have you looked at the video on a TV monitor? Everything should look correct.
If you want a version to play specificaly on a computer, then make a final version via Compressor and deinterlace using frame controls.
Dave Skinner
on Oct 17, 2011 at 7:34:50 am
No i haven't looked at it on a TV monitor.
I have edited things before and haven't had this problem so I figured i'm missing a setting somewhere or something.
unfortunately Compressor is not working at the moment. It wont allow me to press the 'submit' button, so thats the next ting on the list to fix.
Dave Skinner
on Oct 17, 2011 at 7:32:12 am
Sequence Settings:
1920x1080 HDTV 1080i(16:9)
Pixel Aspect Ratio: Square
Field Dominance: Upper (Odd)
Editing Timebase: 25
Compressor: XDCAM EX 1080i50 (35Mb/s VBR)
I've edited things before. Shot on different cameras (including the EX3) etc and haven't had this problem before
Rafael Amador
on Oct 17, 2011 at 9:18:07 am
you said that you shot p25 but you are editing in an interlaced sequence.
You are generating the interlacing.
Edit in a p25 sequence.
rafael
http://www.nagavideo.com
Chris Tompkins
on Oct 17, 2011 at 1:46:09 pm
Normal. That is what interlaced footage looks like on the screen.
Always view footage on an external TV monitor.
Like Rafael, try a proressive sequence settings or verify match with footage.
Chris Tompkins
Video Atlanta LLC
