How do you export a FCP project as AIC to use in another project.
Andre Elliott
on Oct 16, 2011 at 4:15:39 am
I'm working on a music video that is being edited in AIC. I want to export the project and keep it in the AIC codec to that I can open it back up in FCP and make it smaller to add a bit of sharpness since I don't need it to take up the full space. Doing this in the orginal project would require me to make each clip smaller and would take too long try to match the size of each clip. I want to export the project and reopen it in a new project. Since it'll all be joined together I could shrink the whole sequence at once rather than clip by clip.
Rafael Amador
Re: How do you export a FCP project as AIC to use in another project.
on Oct 16, 2011 at 11:04:57 am
Once ready to export, change the sequence codec to AIC and export.
You can also export through "QT Conversion". Chose AIC, "current size" and audio PCM 48Khz/16b.
rafael
http://www.nagavideo.com
