Select All Clips Forward
Dale Robinson
on Oct 14, 2011 at 7:39:33 pm
Recently I was working on a long project and I noticed that every time I selected the T key I was already set up to select all clips forward without having to press TTT. I am now working on another project and I am back to having to select TTT every time I want to Select All Clips forward.
Is there a way to set the T key stay in the Select All Clips Forward mode without having to press TTT ?
Bret Williams
Re: Select All Clips Forward
on Oct 15, 2011 at 3:38:31 am
I think just choose it in the tool pallette. Click and hold for the different options. However, I usually use t, then hold shift. Same result.
