FCP7 Error: Out of Memory????? I know people post this alot but I still haven't gotten an answer for my situation.. Thanks
Bryan Johnson
on Oct 13, 2011 at 11:18:59 pm
I know this is a commonly asked question..
But I am going to keep it short and simple for you Pros' out there.
I have a MacBook Pro. I am running on Mac OS X Version 10.6.8
PROCESSOR: 2.66 GHz Intel Core 2 Duo
MEMORY: 8 GB 1067 MHz DDR3
STARTUP DISK: Macintosh HD
I was editting in FCP7 and everything was fine until I messed with the settings. I shot footage with my GOPRO and the clips in the browser that I imported, everytime I try to view the clips they skip and lag.
The movie plays fine though in the timeline. Is there any hope?
PHOTOS***********
Thanks guys, sorry if this question has been posted alot.
David Roth Weiss
Re: FCP7 Error: Out of Memory????? I know people post this alot but I still haven't gotten an answer for my situation.. Thanks
on Oct 13, 2011 at 11:55:16 pm
Based upon your screenshots you've got loads of issues; primary among them is that you're trying to edit h.264, which is not an editing codec in FCP. You'll have to transcode all of that material to ProRes before editing. There are a zillion posts on the subject of transcoding h.264, so you'll have to do a search to see how that's done with Compressor or MPEG Streamclip.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Scott Sheriff
on Oct 14, 2011 at 3:35:40 am
Geez Wally, H.264. Who woulda' thunk it?
Scott Sheriff
Director
http://www.sstdigitalmedia.com
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." ---Red Adair
Where were you on 6/21?
Steve Eisen
on Oct 14, 2011 at 12:01:24 am
This is mention a million times a day. h.264 is not an editing codec for FCP 7. Transcode your clips to ProRes before you edit inside FCP. That should solve your problem.
Convert your mp3's to 16 bit 48k.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
David Roth Weiss
on Oct 14, 2011 at 12:08:03 am
You need a bit of caffeine to keep up with me Steve. :)
David Roth Weiss
Los Angeles
Bryan Johnson
on Oct 14, 2011 at 12:29:44 am
Thanks for your help guys. I knew it was a frequently asked question. You guys are fast.
Rafael Amador
on Oct 14, 2011 at 1:26:03 am
Although not supported, you can CUT GoPro stuff on FC without problem and even applying some basic filters, but don't try to go further.
To export, set the sequence to Prores, AND check Render in YUV.
I don't know why GoPro stuff asks for RGB rendering.
rafael
http://www.nagavideo.com
David Roth Weiss
on Oct 14, 2011 at 1:34:32 am
Actually, I'm going to disagree with Rafa on this one. While you can cut very limited amounts of h.264 on the timeline, anything over just a minute or two will make all kinds of things crap out in FCP. Hence the Out of Memory error message that is the subject of this thread.
David Roth Weiss
Los Angeles
Scott Sheriff
on Oct 14, 2011 at 3:44:49 am
[David Roth Weiss] "Actually, I'm going to disagree with Rafa on this one. While you can cut very limited amounts of h.264 on the timeline, anything over just a minute or two will make all kinds of things crap out in FCP. Hence the Out of Memory error messag"
Gotta agree with David. Even if you can cut some H.264, if you push your system enough it's going to crash. And then you risk corrupting your footage or your system files.
Scott Sheriff
Director
Bryan Johnson
on Oct 14, 2011 at 4:28:25 am
Thank you my friend.
Rafael Amador
on Oct 14, 2011 at 5:30:14 am
And I don't gonna disagree with David and Scott.
The GoPro sequences I've processed were no longer than a minute, but, believe me, I've been able to run NeatVideo on top (Prores sequence/High Precision) with no problems.
They were just test. If I had to do something longer, I'd transcode.
Rafael
John Pale
on Oct 14, 2011 at 12:50:43 pm
If you have Premiere Pro, it actually plays it pretty well. As does FCPX.
I just went through this with a large Avid project. Just needed to screen and make selects, as there's were many hours recorded. couldn't transcode it all. FCP 7 and Avid (via AMA) couldn't do it without instability.
A 64 bit app does the trick.
Todd Sansom
on Oct 14, 2011 at 6:10:44 pm
Multiple reasons whey go get this error and you look to have managed to have a lot of them. Is this your first FCP project? Look at it like a balance, you need equal things on both sides to optimize your workflow.
Still images are too large, the max image size you can bring into FCP is 4,000 x 4,000 but we've had issues with still over 2,000 x 2,000.
Why are you letterboxing your HD Ninja-ness into a DV/DVCPRO sequence? Match your sequence settings with your footage for starters. You won't have to render everything and if you need to deliver is some SD variant you out put it that way.
Use MPEGStreamclip to convert your footage to ProRes 422 and tell it to make the audio 16/48kHz (as mentioned). Match your sequence settings to your new ProRes footage.
Todd Sansom
Documentary Filmmaker | Cinematographer | Editor
http://www.sansommedia.com
