From FCP to mobile phone format
Greg Ball
on Oct 13, 2011 at 7:06:31 pm
I'm working for a client that would like us the create a video that can be triggered by a QR code and play on Mobile devices. I imagine that would be a 3GPP formatted video. Has anybody done this? How can we convert this from QuickTime to 3GPP? Or is there a better way?
Thanks.
Ryan Holmes
Re: From FCP to mobile phone format
on Oct 13, 2011 at 7:31:55 pm
You can use Quicktime Pro, Compressor, Sorenson Squeeze, or Telestream Episode to encode to 3gp. Or you can use a h.264 mp4 as your file - playable on computers, tablets, and mobile devices.
Ryan
John Fishback
on Oct 13, 2011 at 7:32:40 pm
Compressor has presets for a bunch of mobile formats. However, make sure you know all the devices your clients need to play. That will affect your choice of codec to use. You may need to supply clips in various formats. The code would determine what type of device is connected and then play the correct stream.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Greg Ball
on Oct 13, 2011 at 7:37:11 pm
Thanks for the quick responses. The types of mobile devices are unlimited, as this would be for consumers to use in a retail environment. But at least you got me going in the right direction.
John Fishback
on Oct 13, 2011 at 7:48:02 pm
I suggest you ask your client to spec the devices they want - or at least the codecs. Then you're not left hanging if you don't supply everything they want or need. The choice should be theirs. You shouldn't have to guess.
John
