FCP 7 Pref Anomoly
peter tours
FCP 7 Pref Anomoly
on Oct 12, 2011 at 1:32:55 pm
Does anyone know why this second and odd set of prefs is appearing along with the normal prefs? 3064_screenshot20111005at4.56.51pm.png.zip
7.0.3
10.6.7
12 Core 12gb RAM
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to infinity and beyond!
Rafael Amador
Re: FCP 7 Pref Anomoly
on Oct 12, 2011 at 2:49:11 pm
Because they exists in your User >Library > Preferences > By host.
rafael
http://www.nagavideo.com
peter tours
on Oct 12, 2011 at 3:13:12 pm
I don't understand. Did you look at the screen grab? Please explain. I understand prefs pretty well. Plse look at the screen grab.
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Andy Neil
on Oct 12, 2011 at 6:22:44 pm
Well, you didn't stretch the name out so it was entirely visible so I can't be sure what it is or how it got there. However, you're clearly only supposed to have one FCP plist so I'd delete the "long name" one.
Andy
http://www.timesavertutorials.com
peter tours
on Oct 12, 2011 at 6:44:15 pm
Not sure what you guys are seeing - when I download the image I see what I uploaded. It's a find, but reflects what was in finder in the prefs folder. The red labeled item is the whole name of a pref file that should not exist on this planet as far as I know. The entry above the red labeled line is the normal pref file I would expect to see.
If you don't see that, let me know and I will send you the image. Thanks!
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Andy Neil
on Oct 12, 2011 at 7:10:58 pm
Usually you see the "..." in a name in the finder when the OS is truncating a longer name. If you drag the name column edge out does the name lengthen?
Andy
peter tours
on Oct 12, 2011 at 7:15:10 pm
Sorry I trashed prefs after the grab. That was actually what I set out to do when I discovered the anomaly. peter
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Rafael Amador
on Oct 13, 2011 at 6:09:52 am
Again, that file is user/Library/Preferences/By Host.
I guess is something for the system, not for the user manipulation.
What I don't understand is why that window doesn't shows the path to the file as in my computer.
Look at the bottom of the picture:
peter tours
on Oct 13, 2011 at 6:33:06 am
I thought you were getting too humg up on the fact is was a search, but now I get the impression it's supposed to be there and maybe not the anomoly I thought it was.
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
