General Error problem whem working with H.264 mp4 files
Sawi Hsiwi
on Oct 12, 2011 at 6:36:32 am
I am working on editing a wedding video. Each time I try to place two video files in the same sequence I get a 'General Error' prompt. The only way I got around this is by placing each video file in its own sequence, but when I try to copy and paste any of the files from one sequence to a sequence that already contains a video in it, the 'General Error' pops again. I tried adding the video to a different track within the same sequence - same result.
All files were converted from MTS (Canon HD camcorder) to the following format (running time is different for each file but no more than 10 min. each):
***** Analyzed File Results *****
*** General Parameters ***
- Name: 00037.mp4
- Container: MP4 - QuickTime
- Size: 207.62 MB
- Duration: 3mn 21s
- Bitrate: 8 275 Kbps
*** Video Track Parameters ***
- Format: H.264/MPEG-4 AVC
- Bitrate: Max.: Undefined / Average: 8 000 Kbps / Min.: Undefined
- Frame rate (fps): Max.: 29.970 / Average: 29.955 / Min.: 7.492
- Encoding profile: High@L4.0
- Width (Pixel number): 1920*1080
- Pixel Aspect Ratio: 1:1
- Display Aspect Ratio: 16:9
- Interlacing: Progressive
*** First Audio Track Parameters ***
- Format: AAC - MPEG-4 audio
- Bitrate: 128 Kbps
- Resolution: Undefined
- Profile: Low Complexity
- Channel(s): 2 (stereo)
- Position: Front: L R
I am using a Mac Pro 5.1 2x2.4 GHz Quad Core Intel Xeon 11 GB 1066 MHz DDR3 with OS X 10.6.8 and Final Cut Pro 7.0.3.
Thanks in advance,
Sawi Hsiwi
Michael Gissing
Re: General Error problem whem working with H.264 mp4 files
on Oct 12, 2011 at 12:20:06 pm
Convert to Prores422 with uncompressed audio. FCP doesn't edit mp4 with compressed audio
