Graphics from After Effects look fuzzy when I render them In Final Cut Pro
Carmen Allison
on Oct 11, 2011 at 4:31:53 pm
Hi there folks,
I'm having an issue with my After Effects renders in FCP.
I'm working with a HDV1080p25 Sequence and I'm trying to put a graphic over the footage with an alpha channel (rendered out from AE as lossless with alpha, as per usual). The graphic looks totally crisp until I render the sequence. Once rendered it looks awful, almost like a really low bit rate kind of look. I've tried changing the alpha of the clip in FCP, again, all look crisp until I render.
Does anyone have any solutions or have encountered this problem before?
Regards,
Carmen.
