how to list all plug ins of project
Nik Crosina
on Oct 11, 2011 at 9:54:19 am
Hi guys,
I just got a FCP project back from our agency and we will create various different language versions of it in-house. However, is there a easy way of finding out what plug-ins have been used on the projet without trawling through the time-lines.
I am especially interested in the non-standard ones, the ones that do not come with FCP and therefore have to be downloaded and installed separately before we can commence the editing.
Nik C
Neil Patience
Re: how to list all plug ins of project
on Oct 11, 2011 at 4:57:03 pm
Cant think of a way to get a list however what might help you is to select "open" in the canvas window. (use middle of 3 buttons at the top)
Then select the filter tab in the viewer window.
You can then fast scroll through the timeline and for each shot that filters are used they will simply pop up in the viewer window as you scroll past.
Another thing that might help is to switch the "filters" bar on in the timeline, (bottom left corner of timeline - button with 2 lines) that will underline each shot with a green line that has a filter used so you can more easily ignore those that dont have filters.
That would be a lot quicker than checking every individual shot.
best wishes
Neil
http://www.patience.tv
