HDV timeline footage to HD monitor?
Phil Giriodi
on Oct 9, 2011 at 4:13:22 am
Mac Intel OS 10.6.8
FCP 7.0.3
I am still unable to view HDV footage from my timeline on my HD monitor using a Blackmagic Intensity internal card as output.HDMI TO HDMI cable.
The 1440:1080 is grayed out. All captured footage is displayed as 1920:1080.
I was struggling with this problem a couple of weeks ago but had to go out of town before a solution. The two suggestions from forum members did not solve the problem.
Your help would be most appreciated.
Jerry Hofmann
Re: HDV timeline footage to HD monitor?
on Oct 9, 2011 at 10:51:25 pm
Make sure you're drivers for the card are the latest?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Phil Giriodi
on Oct 10, 2011 at 1:42:17 am
Thanks Jerry. You did it again! That is exactly what the problem was. I was under the impression that I had the latest drivers but I did not.
Thanks again.
All the best,
Grant
Jerry Hofmann
on Oct 10, 2011 at 12:57:32 pm
Hey, it's a standard response to the problem... Glad it worked this time!
Jerry
Current DVD:
Phil Giriodi
on Oct 10, 2011 at 2:56:11 pm
Jerry,
A big problem: After turning the system off for the night FCP will no longer boot this morning. It goes through the motions, however, it gets to a certain point and then disappears.
Tried everything that I can think of.
What do you suggest?
Thanks.
Grant
Phil Giriodi
on Oct 10, 2011 at 3:38:32 pm
Success! Reinstalled Blackmagic software from internet. Now working as expected. May have to reinstall each time system is booted which doesn't seem right.
Anyway, thanks again Jerry.
