Converting PAL to NTSC
Lawrence Vaughan
on Oct 4, 2011 at 5:23:12 pm
I have looked on here already and can only find results for After Effects. I have a project, filmed and edited in PAL and have a request for a DVD copy for play back in the USA.
Is it a case of changing the frame rate on export, then burning an NTSC disc in iDVD / Encore? Or, do I need to do something with the footage?
Neil Patience
Re: Converting PAL to NTSC
on Oct 4, 2011 at 7:39:42 pm
Hi Lawrence
If you only require a DVD you could try using something like the Nattress plug in.
http://www.nattress.com/Products/standardsconversion/standardsconversion.ht...
It works pretty well but it does have some limitations and could be a long render.
I have used it on short clips and odd shots and for that it can be a life saver. Never tried it on anything longform - others may have experience of that.
To be honest the only proper way to do this is by using a hardware standards convertor, certainly if you were supplying something for broadcast, I would be looking at using something like Alchemist PHC
best wishes
Neil
http://www.patience.tv
Lawrence Vaughan
on Oct 5, 2011 at 6:50:34 pm
thanks for your help. I'll see what the results are like. The DVD I'm converting is just under an hour. This may be unsuitable...
