Final Cut 7 Spinning Death Wheel on Launch can open under other user name
Devin Tanchum
on Oct 3, 2011 at 7:51:28 pm
Hi All,
Final Cut Studio 3
OS 10.6.7
Mac Pro 2 x 2.26 GHz Quad Core Intel
8 GB 1066 MHz DDR3
This is infuriating. FCP is loading up until "master templates" and then spins endlessly. If I login as a different user, it opens without a problem.
Neither trashing prefs nor reinstalling helps. All other FCS applications are working fine under my usual user name.
This is the first time this has ever happened. It was working fine on friday, I booted up today and all hell broke loose.
I really hope you can help. Please let me know if you need further information.
Thank you,
Devin
Here is the report generated after force quitting:
Date/Time: 2011-10-03 12:47:45 -0700
OS Version: 10.6.7 (Build 10J869)
Architecture: x86_64
Report Version: 7
Command: Final Cut Pro
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Version: 7.0 (7.0)
Build Version: 22
Project Name: FCPApp
Source Version: 906181654
Parent: launchd [933]
PID: 1487
Event: hang
Duration: 4.99s (sampling started after 2 seconds)
Steps: 9 (100ms sampling interval)
Pageins: 0
Pageouts: 0
Process: Final Cut Pro [1487]
UID: 502
Thread 158d
User stack:
9 start + 41 (in Final Cut Pro) [0x3999]
9 _start + 209 (in Final Cut Pro) [0x3a6b]
9 main + 54 (in Final Cut Pro) [0x2c1aa8]
9 KGMainEvent(void*) + 51 (in Final Cut Pro) [0x15464f]
9 RunApplicationEventLoop + 243 (in HIToolbox) [0x97be1d4f]
9 ToolboxEventDispatcher + 86 (in HIToolbox) [0x97be1c17]
9 SendEventToEventTarget + 52 (in HIToolbox) [0x97a587f3]
9 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 (in HIToolbox) [0x97a35ef6]
9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 (in HIToolbox) [0x97a37080]
9 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006 (in HIToolbox) [0x97a6aa24]
9 SendEventToEventTargetWithOptions + 58 (in HIToolbox) [0x97a35d55]
9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 (in HIToolbox) [0x97a36c2f]
9 TEventHandler::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 64 (in HIToolbox) [0x97afea84]
9 HIStdAppHandler::HandleEvent(OpaqueEventHandlerCallRef*, TCarbonEvent&) + 206 (in HIToolbox) [0x97afd996]
9 AEProcessEvent + 160 (in HIToolbox) [0x97bec25e]
9 AEProcessAppleEvent + 50 (in HIToolbox) [0x97a6b197]
9 aeProcessAppleEvent + 197 (in AE) [0x90daad61]
9 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 43 (in AE) [0x90daae57]
9 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 166 (in AE) [0x90daaf58]
9 OpenApplication(AEDesc const*, AEDesc*, long) + 73 (in Final Cut Pro) [0x4130d3]
9 KGInit() + 173 (in Final Cut Pro) [0x245643]
9 KGFinishLibraries + 130 (in Final Cut Pro) [0x24551e]
9 CallLibs(KGLibActionCode, unsigned char) + 258 (in Final Cut Pro) [0x245314]
9 KGReaderLibAction + 1527 (in Final Cut Pro) [0x241d1f]
9 pKGDictRead(KGDictInt**, KGStreamRecord*, KGMessageableRec*) + 53 (in Final Cut Pro) [0x1198a5]
9 pKGDictReadWithFlags(KGDictInt**, KGStreamRecord*, KGMessageableRec*, unsigned long, __CFArray const*) + 580 (in Final Cut Pro) [0x119aec]
9 KGTypeReadPtr + 60 (in Final Cut Pro) [0x12eab8]
9 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 67 (in Final Cut Pro) [0x12af49]
9 KGDictReadInternal + 150 (in Final Cut Pro) [0x119782]
9 KGDictReadArray + 346 (in Final Cut Pro) [0x48e0]
9 KGDictReadInternal + 124 (in Final Cut Pro) [0x119768]
9 KGDictReadHash + 38 (in Final Cut Pro) [0x1fc84]
9 KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 308 (in Final Cut Pro) [0x1fb72]
9 KGTypeReadValue + 128 (in Final Cut Pro) [0x12ea72]
9 ReadKGFile(void*, KGStreamRecord*, KGReferenceTableInt*) + 8176 (in Final Cut Pro) [0x131492]
9 pKGFileAddOrCheckImportWithKnownAlias(KGFileSpec*, char*, KGDictInt*, KGFileRec**, KGFileRec**, void*) + 1240 (in Final Cut Pro) [0x18bd7e]
9 GetInfoFromReader(KGFileRec*, KGDictInt*, char*) + 374 (in Final Cut Pro) [0x18a7c4]
9 PluginMainEntry(long, long, KGDictInt*, void*) + 7302 (in QTM Reader) [0x1e486f98]
9 AudioExtractor::Extract(void*, unsigned long&) + 12951 (in QTM Reader) [0x1e47162b]
9 AudioExtractor::Extract(void*, unsigned long&) + 468 (in QTM Reader) [0x1e46e568]
9 pKGOpenFile(KGFileRec*, unsigned long) + 167 (in Final Cut Pro) [0x189285]
9 PluginMainEntry(long, long, KGDictInt*, void*) + 6880 (in QTM Reader) [0x1e486df2]
9 isNuggetFile(char const*) + 2909 (in QTM Reader) [0x1e46bc7b]
9 isNuggetFile(char const*) + 1197 (in QTM Reader) [0x1e46b5cb]
9 PluginStart + 5981 (in QTM Reader) [0x1e45b22b]
9 NewMovieFromFile + 61 (in QuickTime) [0x90cc94e4]
9 NewMovieFromFile_priv + 50 (in QuickTime) [0x90b6a52d]
9 NewMovieFromFilePriv + 1875 (in QuickTime) [0x90ab013d]
9 getNewMovieFromFileUsingImporters + 1555 (in QuickTime) [0x90ab0993]
9 newMovieFromFileFromComponent + 875 (in QuickTime) [0x90b6a0f4]
9 MovieImportDataRef + 91 (in QuickTime) [0x90cd80e8]
9 CallComponentDispatch + 29 (in CarbonCore) [0x97321781]
9 ImportMPEGDispatcher + 953 (in QuickTimeMPEG) [0x3b4fa32f]
9 ImportMPEGImportDataRef + 1007 (in QuickTimeMPEG) [0x3b4f9cd8]
8 S_DoTheImport + 1101 (in QuickTimeMPEG) [0x3b4f85c9]
8 ReadFromBufferObject + 415 (in QuickTimeMPEG) [0x3b505bfb]
8 DataHFinishData + 53 (in QuickTime) [0x90cd72fc]
8 CallComponentDispatch + 29 (in CarbonCore) [0x97321781]
8 SDH_ComponentDispatch + 143 (in QuickTimeComponents) [0x941967b1]
8 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54 (in CarbonCore) [0x97329014]
8 SDH_FinishData + 95 (in QuickTimeComponents) [0x941991de]
7 RSFinish + 103 (in QuickTimeComponents) [0x9419ae0b]
7 TSWaitOnSemaphoreCommon + 472 (in CarbonCore) [0x97300b54]
7 TSWaitOnCondition + 126 (in CarbonCore) [0x9731548e]
7 pthread_cond_wait$UNIX2003 + 73 (in libSystem.B.dylib) [0x977de998]
7 __semwait_signal + 10 (in libSystem.B.dylib) [0x977dd046]
1 RSFinish + 87 (in QuickTimeComponents) [0x9419adfb]
1 TSSignalSemaphore + 219 (in CarbonCore) [0x97300f7b]
1 pthread_cond_signal + 25 (in libSystem.B.dylib) [0x977e4373]
1 semaphore_signal_thread_trap + 10 (in libSystem.B.dylib) [0x977af0ca]
1 S_DoTheImport + 1614 (in QuickTimeMPEG) [0x3b4f87ca]
1 SHDecodeIdle + 43 (in QuickTime) [0x90ccb3a7]
1 CallComponentDispatch + 29 (in CarbonCore) [0x97321781]
1 MPEGVideoDispatcher + 212 (in QuickTimeMPEG2) [0x3b5a5612]
1 MPEGVideoIdle + 2130 (in QuickTimeMPEG2) [0x3b5a4bca]
1 QTYieldToThread + 470 (in QuickTimeMPEG2) [0x3b57235d]
1 pthread_cond_wait + 48 (in libSystem.B.dylib) [0x9782545f]
1 semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x977af0e2]
Kernel stack:
7 semaphore_wait_continue + 0 [0x22a3e1]
2 lo_mach_scall + 280 [0x2a1028]
1 get_user_regs + 548 [0x294e25]
1 semaphore_wait_signal_trap + 34 [0x22a8b1]
1 semaphore_wait_signal_trap_internal + 96 [0x22a86f]
1 semaphore_destroy + 703 [0x22a728]
1 thread_block + 33 [0x2272eb]
1 thread_block_reason + 309 [0x227247]
1 thread_go + 1961 [0x226623]
1 thread_setrun + 1360 [0x225851]
1 machine_idle + 239 [0x2abb9a]
1 get_user_regs + 465 [0x294dd2]
1 current_proc + 0 [0x5022ae]
Thread 15a7 DispatchQueue 1215587655
User stack:
9 thread_start + 34 (in libSystem.B.dylib) [0x977dc682]
9 _pthread_start + 345 (in libSystem.B.dylib) [0x977dc7fd]
9 Thread::RunHelper(void*) + 20 (in Final Cut Pro) [0x46ac0c]
9 WorkUnitPerformer::Run() + 55 (in Final Cut Pro) [0x4e5a4b]
9 Synchronizable::Wait() + 53 (in Final Cut Pro) [0x43ee7b]
9 pthread_cond_wait + 48 (in libSystem.B.dylib) [0x9782545f]
9 semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x977af0e2]
Kernel stack:
9 semaphore_wait_continue + 0 [0x22a3e1]
Thread 15b7 DispatchQueue -1953650611
User stack:
9 threadProc(void*) + 17 (in AECore) [0x2ad17fb9]
9 aecore::CThread::runThread() + 34 (in AECore) [0x2ad1a022]
9 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234 (in DistributedObjects) [0x2bb373b2]
9 CFRunLoopRun + 84 (in CoreFoundation) [0x936e43a4]
9 CFRunLoopRunSpecific + 452 (in CoreFoundation) [0x936de464]
9 __CFRunLoopRun + 2079 (in CoreFoundation) [0x936df37f]
9 mach_msg_trap + 10 (in libSystem.B.dylib) [0x977af09a]
Kernel stack:
9 ipc_mqueue_receive_continue + 0 [0x210cea]
Thread 1599
User stack:
9 start_wqthread + 30 (in libSystem.B.dylib) [0x977d4b66]
9 _pthread_wqthread + 390 (in libSystem.B.dylib) [0x977d4d21]
9 _dispatch_worker_thread2 + 240 (in libSystem.B.dylib) [0x977d529e]
9 _dispatch_queue_invoke + 163 (in libSystem.B.dylib) [0x977d54f9]
9 kevent + 10 (in libSystem.B.dylib) [0x977d5922]
Kernel stack:
9 kevent + 97 [0x4783e9]
Thread 15a0
User stack:
9 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x977ce066]
Kernel stack:
9 sleep + 52 [0x48eeb0]
Thread 15a6
User stack:
9 DisplayQueue::Run() + 681 (in Final Cut Pro) [0x429495]
Kernel stack:
Thread 15a8
User stack:
Kernel stack:
Thread 15a9
User stack:
Kernel stack:
Thread 15aa
User stack:
Kernel stack:
Thread 15ab
User stack:
Kernel stack:
Thread 15ac
User stack:
Kernel stack:
Thread 15ad
User stack:
Kernel stack:
Thread 15b2
User stack:
9 AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317 (in DVCPROHDMuxer) [0x27f8898f]
Kernel stack:
Thread 15b3
User stack:
9 CAPThread::Entry(CAPThread*) + 96 (in CoreMediaIOServicesPrivate) [0x10ef81c]
9 MIO::DAL::RunLoop::OwnThread(void*) + 157 (in CoreMediaIOServicesPrivate) [0x10ed9ab]
9 CFRunLoopRunInMode + 97 (in CoreFoundation) [0x936de291]
Kernel stack:
Thread 15b8
User stack:
Kernel stack:
Thread 15b9
User stack:
9 ReadSchedulerThreadEntryPoint + 4698 (in QuickTimeComponents) [0x9419d591]
9 TSWaitOnSemaphoreCommon + 511 (in CarbonCore) [0x97300b7b]
9 TSWaitOnConditionTimedRelative + 242 (in CarbonCore) [0x97300e3d]
9 pthread_cond_timedwait_relative_np + 47 (in libSystem.B.dylib) [0x9780baa8]
8 semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x977af0fa]
1 _pthread_cond_wait + 1514 (in libSystem.B.dylib) [0x977dce45]
1 _pthread_cond_remove + 119 (in libSystem.B.dylib) [0x977de8ca]
1 __spin_lock + 13 (in commpage [libSystem.B.dylib]) [0xffff026d]
Kernel stack:
6 semaphore_wait_continue + 0 [0x22a3e1]
2 get_user_regs + 548 [0x294e25]
2 semaphore_timedwait_signal_trap + 48 [0x22acfb]
2 semaphore_timedwait_signal_trap_internal + 226 [0x22aca6]
2 semaphore_destroy + 703 [0x22a728]
2 thread_block + 33 [0x2272eb]
1 thread_block_reason + 331 [0x22725d]
1 thread_dispatch + 1517 [0x226dfd]
1 ml_set_interrupts_enabled + 47 [0x2a35a7]
1 lo_allintrs + 302 [0x2a0b6e]
1 interrupt + 171 [0x2aa0d6]
1 lapic_interrupt + 126 [0x2b16c2]
1 intel_startCPU + 885 [0x2b2825]
1 sync_iss_to_iks + 124 [0x2a99dc]
Thread 15ba
User stack:
7 aio_suspend$UNIX2003 + 10 (in libSystem.B.dylib) [0x9787633e]
2 AIOFileThread(void*) + 1127 (in CarbonCore) [0x9735b6ee]
2 TSWaitOnSemaphoreCommon + 511 (in CarbonCore) [0x97300b7b]
2 TSWaitOnConditionTimedRelative + 242 (in CarbonCore) [0x97300e3d]
2 pthread_cond_timedwait_relative_np + 47 (in libSystem.B.dylib) [0x9780baa8]
2 semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x977af0fa]
Kernel stack:
7 lo_unix_scall + 280 [0x2a0f08]
7 unix_syscall + 579 [0x4f5d0a]
7 aio_suspend_nocancel + 568 [0x46ab38]
7 wakeup + 334 [0x48eb00]
7 lck_mtx_sleep + 87 [0x221a0f]
7 thread_block + 33 [0x2272eb]
4 thread_block_reason + 331 [0x22725d]
4 thread_dispatch + 1966 [0x226fbe]
4 machine_switch_context + 753 [0x2a8a6e]
3 thread_block_reason + 309 [0x227247]
3 thread_go + 1961 [0x226623]
3 thread_setrun + 1360 [0x225851]
3 machine_idle + 239 [0x2abb9a]
2 semaphore_wait_continue + 0 [0x22a3e1]
Thread 1620
User stack:
9 MacThreadFunc + 136 (in QuickTimeMPEG2) [0x3b572646]
9 VideoThreadEntry + 1566 (in QuickTimeMPEG2) [0x3b58fd61]
9 AdvanceToAPictureEndingCode + 49 (in QuickTimeMPEG2) [0x3b5969e9]
9 VideoAdvanceToNextStartCode + 179 (in QuickTimeMPEG2) [0x3b5968ea]
9 VideoWaitForANewChunkInTheQueueAndAppendIt + 227 (in QuickTimeMPEG2) [0x3b58e47e]
9 QTYieldToThread + 470 (in QuickTimeMPEG2) [0x3b57235d]
Kernel stack:
3 lo_mach_scall + 280 [0x2a1028]
3 get_user_regs + 548 [0x294e25]
3 semaphore_wait_signal_trap + 34 [0x22a8b1]
3 semaphore_wait_signal_trap_internal + 96 [0x22a86f]
3 semaphore_destroy + 703 [0x22a728]
3 thread_block + 33 [0x2272eb]
Binary Images:
0x1000 - 0x867ffc com.apple.FinalCutPro 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0x10e0000 - 0x111affb com.apple.CoreMediaIOServicesPrivate 34.0 (1360) <8F44EB7A-C722-55D2-AF12-838553442BEE> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x1e458000 - 0x1e497fef com.apple.FinalCutPro.Plugins.QTM Reader 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x27f71000 - 0x27fd6fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <483DD62C-46C4-36AA-6A1C-2DEA6F062863> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x2ad00000 - 0x2ae5aff7 com.apple.AECore 3.5.3 (3.5.3) <2BAD733C-D2F3-F9FD-C5CD-22C23820EE15> /Library/Frameworks/AECore.framework/Versions/A/AECore
0x2bb24000 - 0x2bb98ff8 com.apple.qmaster.do 3.5 (3.5) <4B871D53-4986-7D55-1F62-9ABC64D20FC8> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x3b4f5000 - 0x3b55cfe7 com.apple.QuickTimeMPEG.component 7.6.6 (1756.15) <02371681-9219-5D3C-7AAD-68426F5D6B30> /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/QuickTimeMPEG
0x3b570000 - 0x3b5acff7 com.apple.QuickTimeMPEG2.component 7.6 (1290) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/QuickTime/QuickTimeMPEG2.component/Contents/MacOS/QuickTimeMPEG2
0x90a56000 - 0x90d4ffef com.apple.QuickTime 7.6.6 (1756.15) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x90da7000 - 0x90ddaff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x936a2000 - 0x9381dfe7 com.apple.CoreFoundation 6.6.4 (550.42) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93be5000 - 0x94b38fe3 com.apple.QuickTimeComponents.component 7.6.6 (1756.15) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x972ba000 - 0x975daff3 com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x977ae000 - 0x97955ff7 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
0x97a2f000 - 0x97d53fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0xffff0000 - 0xffff1fff commpage [libSystem.B.dylib] ??? (???) /usr/lib/libSystem.B.dylib
Process: AirPort Base Station Agent [1380]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 502
Thread bf7 DispatchQueue 1
User stack:
9 ??? (in AirPort Base Station Agent + 5692) [0x10000163c]
9 NSApplicationMain + 364 (in AppKit) [0x7fff87c381a8]
9 -[NSApplication run] + 395 (in AppKit) [0x7fff87c3f48b]
9 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x7fff87c797a9]
9 _DPSNextEvent + 718 (in AppKit) [0x7fff87c79e64]
9 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x7fff88e094ac]
9 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff88e095f3]
9 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff88e097ee]
9 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff841e5dbf]
9 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff841e6932]
9 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff864a029a]
Kernel stack:
Thread c09 DispatchQueue 2
User stack:
9 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff864b9fc5]
9 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff864ba128]
9 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff864ba7fe]
9 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff864bacd4]
9 kevent + 10 (in libSystem.B.dylib) [0x7fff864b912a]
Kernel stack:
Thread c3a
User stack:
9 thread_start + 13 (in libSystem.B.dylib) [0x7fff864d93a9]
9 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff864d94f6]
9 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x7fff864e3e52]
Kernel stack:
Thread c3b
User stack:
9 ??? (in AirPort Base Station Agent + 117988) [0x10001cce4]
9 ??? (in AirPort Base Station Agent + 106856) [0x10001a168]
9 ??? (in AirPort Base Station Agent + 118817) [0x10001d021]
9 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff864daf8a]
Kernel stack:
Binary Images:
0x100000000 - 0x100027fff com.apple.AirPortBaseStationAgent 1.5.5 (155.2) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
0x7fff8419a000 - 0x7fff84311fe7 com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8649f000 - 0x7fff86660fff libSystem.B.dylib ??? (???) <9BAEB2F2-B485-6349-E1AB-637FE12EE770> /usr/lib/libSystem.B.dylib
0x7fff87c36000 - 0x7fff8862cfff com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff88ddb000 - 0x7fff890d9fff com.apple.HIToolbox 1.6.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process: AppleSpell [1435]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID: 502
Thread e34
User stack:
9 ??? (in AppleSpell + 4816) [0x1000012d0]
9 ??? (in AppleSpell + 5472) [0x100001560]
9 -[NSSpellServer run] + 72 (in Foundation) [0x7fff832b7eee]
9 CFRunLoopRun + 70 (in CoreFoundation) [0x7fff841e5b46]
Kernel stack:
Thread e35 DispatchQueue 2
User stack:
Kernel stack:
Thread 163a
User stack:
9 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff864b9f4a]
Kernel stack:
9 bsdthread_create + 1313 [0x4d22d1]
Binary Images:
0x100000000 - 0x1000a9fe7 com.apple.AppleSpell 1.6.2 (62.2) /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
0x7fff83239000 - 0x7fff834bcfe7 com.apple.Foundation 6.6.6 (751.53) <476E617B-B59B-53DE-991D-98C1993BCBCE> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: autofsd [308]
Path: /usr/libexec/autofsd
UID: 0
Thread 369 DispatchQueue 1
User stack:
9 ??? (in autofsd + 5340) [0x1000014dc]
9 ??? (in autofsd + 6461) [0x10000193d]
Kernel stack:
Thread 37d DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100001ff7 autofsd ??? (???) /usr/libexec/autofsd
Process: blued [16]
Path: /usr/sbin/blued
UID: 0
Thread 1b0 DispatchQueue 1
User stack:
9 ??? (in blued + 5384) [0x100001508]
9 ??? (in blued + 151651) [0x100025063]
9 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x7fff832846a3]
9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x7fff832847c4]
Kernel stack:
Thread 1c6 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100046fe7 blued ??? (???) <29B9C27D-C2DC-F6BB-6A7C-74676B61665C> /usr/sbin/blued
Process: compressord [863]
Path: /Library/Frameworks/Compressor.framework/Resources/CompressorTranscoder.bundle/Contents/MacOS/compressord
UID: 501
Process: configd [15]
Path: /usr/libexec/configd
UID: 0
Thread 196 DispatchQueue 1
User stack:
9 start + 52 (in configd) [0x100000cf0]
9 main + 2051 (in configd) [0x100001506]
9 server_loop + 72 (in configd) [0x100001d5c]
Kernel stack:
Thread 198 DispatchQueue 2
User stack:
Kernel stack:
Thread 19a
User stack:
9 plugin_exec + 1440 (in configd) [0x1000034c3]
Kernel stack:
Thread 1aa
User stack:
9 _io_pm_force_active_settings + 2271 (in PowerManagement) [0x1000ac3c5]
Kernel stack:
Thread 1b1
User stack:
Kernel stack:
Thread 1bc
User stack:
9 pppcntl_run_thread + 1595 (in PPPController) [0x10071890d]
Kernel stack:
Thread 1643
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100026ff7 configd ??? (???) <74FC6898-E16A-3A28-B6B5-5E185A6B1D19> /usr/libexec/configd
0x1000a9000 - 0x1000baff7 com.apple.SystemConfiguration.PowerManagement 160.0.0 (160.0.0) <11BDE066-A91E-EF41-F46E-6E05053C216D> /System/Library/SystemConfiguration/PowerManagement.bundle/Contents/MacOS/PowerManagement
0x100706000 - 0x10072ffff com.apple.SystemConfiguration.PPPController 1.5 (1.5) /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
Process: ControlCenter [1395]
Path: /Library/Printers/Brother/Utilities/ControlCenter/ControlCenter.app/Contents/MacOS/ControlCenter
UID: 502
Process: coreaudiod [352]
Path: /usr/sbin/coreaudiod
UID: 202
Thread 428 DispatchQueue 1
User stack:
9 ??? (in coreaudiod + 2964) [0x100000b94]
9 ??? (in coreaudiod + 26320) [0x1000066d0]
Kernel stack:
Thread 42b DispatchQueue 2
User stack:
Kernel stack:
Thread 456
User stack:
9 CAPThread::Entry(CAPThread*) + 125 (in CoreAudio) [0x7fff8695e745]
9 HALRunLoop::OwnThread(void*) + 152 (in CoreAudio) [0x7fff86971776]
Kernel stack:
Thread 1649
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x10001fff7 coreaudiod ??? (???) <9A14795C-2B28-130F-43A3-183AB48F75D8> /usr/sbin/coreaudiod
0x7fff86940000 - 0x7fff869bffe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
Process: coreservicesd [315]
Path: /System/Library/CoreServices/coreservicesd
UID: 0
Thread 38a
User stack:
9 ??? (in coreservicesd + 3756) [0x100000eac]
9 _CoreServicesServerMain + 522 (in CarbonCore) [0x7fff8127aace]
Kernel stack:
Thread 390 DispatchQueue 2
User stack:
Kernel stack:
Thread 3ce
User stack:
9 fmodWatchConsumer + 347 (in CarbonCore) [0x7fff8122e76e]
Kernel stack:
Thread 3cf
User stack:
9 read + 10 (in libSystem.B.dylib) [0x7fff864aa986]
Kernel stack:
9 lo64_unix_scall + 77 [0x2a144d]
9 unix_syscall64 + 617 [0x4f6075]
9 read_nocancel + 158 [0x49dac1]
9 write + 312 [0x49d345]
9 get_pathbuff + 3054 [0x306b84]
9 tsleep + 105 [0x48f0eb]
9 wakeup + 786 [0x48ecc4]
9 thread_block + 33 [0x2272eb]
9 thread_block_reason + 331 [0x22725d]
9 thread_dispatch + 1966 [0x226fbe]
9 machine_switch_context + 753 [0x2a8a6e]
Thread 164e
User stack:
8 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff864b9fc5]
8 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff864b9f4a]
Kernel stack:
8 bsdthread_create + 1313 [0x4d22d1]
Binary Images:
0x100000000 - 0x100000fff coreservicesd ??? (???) <2A6BD0A0-7DA6-ABE6-3D55-E260EA69F56F> /System/Library/CoreServices/coreservicesd
0x7fff811ca000 - 0x7fff814fefff com.apple.CoreServices.CarbonCore 861.34 (861.34) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
Process: cupsd [1473]
Path: /usr/sbin/cupsd
UID: 0
Thread 1410
User stack:
9 ??? (in cupsd + 4504) [0x148e89198]
9 ??? (in cupsd + 109891) [0x148ea2d43]
Kernel stack:
Thread 1411
User stack:
9 ??? (in cupsd + 277689) [0x148ecbcb9]
Kernel stack:
Thread 1412
User stack:
Kernel stack:
Binary Images:
0x148e88000 - 0x148ee3ff7 cupsd ??? (???) <09F44E55-81E3-CB4D-3176-4906687B243E> /usr/sbin/cupsd
Process: cvmsServ [342]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
UID: 0
Thread 40d DispatchQueue 1
User stack:
9 ??? (in cvmsServ + 4100) [0x100001004]
9 ??? (in cvmsServ + 23081) [0x100005a29]
9 mach_msg_server + 597 (in libSystem.B.dylib) [0x7fff8651cf14]
Kernel stack:
Binary Images:
0x100000000 - 0x100008fff cvmsServ ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
Process: dbfseventsd [1412]
Path: /Library/DropboxHelperTools/Dropbox_u502/dbfseventsd
UID: 0
Process: dbfseventsd [1414]
UID: 502
Process: dbfseventsd [1413]
UID: 0
Process: DirectoryService [11]
Path: /usr/sbin/DirectoryService
UID: 0
Thread 184 DispatchQueue 1
User stack:
9 start + 52 (in DirectoryService) [0x10000cedc]
9 main + 3061 (in DirectoryService) [0x10000dad9]
Kernel stack:
Thread 194 DispatchQueue 2
User stack:
Kernel stack:
Thread 192 DispatchQueue 8
User stack:
9 _dispatch_worker_thread2 + 239 (in libSystem.B.dylib) [0x7fff864ba7f1]
9 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x7fff864dc284]
9 syscall + 10 (in libSystem.B.dylib) [0x7fff864dc882]
Kernel stack:
Thread 195 DispatchQueue 8
User stack:
9 ____StartKernelListener_block_invoke_8 + 33 (in DirectoryService) [0x1000285ad]
9 semaphore_wait_trap + 10 (in libSystem.B.dylib) [0x7fff864a02d6]
Kernel stack:
Thread 193
User stack:
9 DSLThread::_RunWrapper(void*) + 67 (in DirectoryServiceCore) [0x10017934b]
9 DSCThread::Run() + 36 (in DirectoryServiceCore) [0x1001790ac]
9 CPluginRunLoopThread::ThreadMain() + 150 (in DirectoryService) [0x10001c674]
Kernel stack:
Thread 161a
User stack:
Kernel stack:
Thread 1644
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100120ff7 DirectoryService ??? (???) <3408296C-EC0B-E742-27E1-E5BE8A2D686F> /usr/sbin/DirectoryService
0x100171000 - 0x100182fff com.apple.DirectoryServiceCore.Framework 3.6 (621.11) <58F95644-E6DB-EC87-A8C8-03A65E3BC1AF> /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
Process: diskarbitrationd [14]
Path: /usr/sbin/diskarbitrationd
UID: 0
Thread 18f DispatchQueue 1
User stack:
9 ??? (in diskarbitrationd + 4064) [0x100000fe0]
9 ??? (in diskarbitrationd + 32876) [0x10000806c]
Kernel stack:
Thread 19b DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x10001bfef diskarbitrationd ??? (???) /usr/sbin/diskarbitrationd
Process: distnoted [17]
Path: /usr/sbin/distnoted
UID: 1
Thread 1b2 DispatchQueue 1
User stack:
9 ??? (in distnoted + 3620) [0x100000e24]
9 ??? (in distnoted + 3717) [0x100000e85]
Kernel stack:
Thread 1b3 DispatchQueue 2
User stack:
Kernel stack:
Thread 1646
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100000fff distnoted ??? (???) <92B9638C-E784-F96A-27F4-76F21E79A832> /usr/sbin/distnoted
Process: Dock [937]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
UID: 502
Thread 9ca DispatchQueue 1902734434
User stack:
9 ??? (in Dock + 17200) [0x100004330]
9 ??? (in Dock + 18296) [0x100004778]
Kernel stack:
Thread 9ce DispatchQueue 2
User stack:
Kernel stack:
Thread bb3
User stack:
6 ??? (in Dock + 87651) [0x100015663]
6 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff864daf8a]
3 clock_sleep_trap + 10 (in libSystem.B.dylib) [0x7fff864a038a]
Kernel stack:
3 lo64_mach_scall + 77 [0x2a149d]
3 thread_setuserstack + 405 [0x295168]
3 clock_sleep_trap + 407 [0x21a6e7]
3 thread_block_reason + 331 [0x22725d]
3 thread_dispatch + 1966 [0x226fbe]
3 machine_switch_context + 753 [0x2a8a6e]
Thread 159c
User stack:
7 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff864b9f4a]
2 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff864ba128]
2 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff864ba7fe]
2 _dispatch_queue_invoke + 57 (in libSystem.B.dylib) [0x7fff864bac54]
2 _dispatch_queue_drain + 261 (in libSystem.B.dylib) [0x7fff864badfc]
2 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff864bacd4]
2 _dispatch_source_invoke + 273 (in libSystem.B.dylib) [0x7fff864bb913]
2 ??? (in Dock + 210121) [0x1000334c9]
2 CGSReenableUpdate + 25 (in CoreGraphics) [0x7fff809a1f14]
2 CGSReenableUpdateForConnections + 359 (in CoreGraphics) [0x7fff809a207e]
2 _CGSReenableUpdateForConnections + 186 (in CoreGraphics) [0x7fff809a2205]
2 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff864a029a]
Kernel stack:
7 bsdthread_create + 1313 [0x4d22d1]
2 ipc_mqueue_receive_continue + 0 [0x210cea]
Thread 163d
User stack:
7 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff864b9fc5]
Kernel stack:
2 bsdthread_create + 1477 [0x4d2375]
Thread 164f
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100177ff7 com.apple.dock 1.7 (769.16.1) /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
0x7fff8098e000 - 0x7fff8108b06f com.apple.CoreGraphics 1.545.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
Process: Dropbox [1403]
Path: /Applications/Dropbox.app/Contents/MacOS/Dropbox
UID: 502
Process: dynamic_pager [302]
Path: /sbin/dynamic_pager
UID: 0
Thread 363 DispatchQueue 1
User stack:
9 ??? [0x1000013ec]
9 ??? [0x1000023eb]
9 ??? [0x100001cae]
9 ??? [0x100001a30]
9 ??? [0x10000198f]
9 ??? [0x7fff864a029a]
Kernel stack:
Process: Finder [939]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
UID: 502
Thread 9cc DispatchQueue 1
User stack:
9 ??? (in Finder + 20828) [0x10000515c]
9 ??? (in Finder + 20889) [0x100005199]
