HDV playback on HD Monitor
Phil Giriodi
on Oct 1, 2011 at 4:45:58 am
MAC OS 10.5.8 Dual-Core Intel Xeon
FCP 5.1.4
Blackmagic Intensity Card (internal) for external monitor
HVR-M10U Deck
Sony HD Monitor-HDMI input.
Problem: Timeline footage will not playback on external Sony HD monitor.
1. Sony HVR-M1OU deck is recognized by the system. I can capture in HDV. I can also conform the timeline footage and record to the Sony deck in HDV.
2. However, I am unable to see the footage from the timeline on my external Sony HD monitor. I need to be able to highlight "HDV (1440x1080)80i" in the Audio/Video Settings, however, it is grayed out.
Your guidance will be most appreciated.
Thank you.
Steve Eisen
Re: HDV playback on HD Monitor
on Oct 1, 2011 at 1:09:19 pm
You will need to choose a 1080i Blackmagic setup.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
on Oct 1, 2011 at 4:49:13 pm
Under VIEW>VIDEO PLAYBACK, you need to choose that Blackmagic option...
Shane
Phil Giriodi
on Oct 1, 2011 at 4:56:46 pm
Steve & Shane,
Thanks for your guidance. I was under the impression that I had attempted this previously, however, I might have overlooked it. I tried everything that I could think of and the 1440:1980 was still grayed out.
I'll give it another go after I complete my present SD project.
Thanks again.
Phil
Michael Gissing
on Oct 2, 2011 at 2:24:54 am
The card should be set to display 1920 x 1080i 8 bit for playing HDV timelines. There should be a Blackmagic 1080 HDV preset which in Easy Setup sets the output to this.
