can't center pan audio clips
Gerret Warner
on Sep 30, 2011 at 7:59:58 pm
I've edited on FCP for years but never come across this problem before. I can't center pan my audio clips so they play mono into both speakers. Is it possible I set a preference unintentionally? Or might it be something else?
GW
Mark Spano
Re: can't center pan audio clips
on Sep 30, 2011 at 8:30:37 pm
It is likely that your Sequence Audio Output Setting is set to discrete outputs. Go into your Sequence settings - Audio Output tab, and choose the Stereo Monitoring preset. You should get your pan controls back.
Michael Gissing
on Sep 30, 2011 at 10:46:24 pm
Are the clips linked stereo? Try unlinking and see if the panning is now available.
Gerret Warner
on Oct 3, 2011 at 4:29:58 pm
Many thanks, Mark. that did the trick.
Gerret
