MPEG 2 MainConcept
Sam Caino
MPEG 2 MainConcept
on Sep 29, 2011 at 9:49:01 pm
Is it possible, perhaps with the correct codecs installed, to import and MPEG 2 that was encoded with the MainConcept encoder directly into Final Cut Pro and edit with it? What, if any, software would need to be installed?
Rafael Amador
Re: MPEG 2 MainConcept
on Sep 29, 2011 at 10:13:41 pm
Hi Sam,
FC officially supports just few MPEG-2 flavors (XDCAM, HDV,..) what doesn't means that can not cope with others.
I think you can cut more of them. Other operations will depend.
Try it.
Do it in a Prores (or any other editable codec) sequence.
You may have problems with the audio if this comes as MP2. FC can't read it.
If you intend to do more than a basic editing, better transcode.
rafael
http://www.nagavideo.com
