mxf files
Tamsyn Reynolds
mxf files
on Sep 29, 2011 at 11:30:38 am
Hi
I've just shot a whole lot of footage as MXF files on a canon HD camera. In some of my folders, the MXF files are missing. So in each of the other folders there are 5 files, but in one of them only 4.
i imagine that there's nothing i can do but thought i'd ask just in case.
by the way, i watched a preview of some of the clip on the camera, so i know they once existed.
thanks
tamsyn
Chris Tompkins
Re: mxf files
on Sep 29, 2011 at 1:24:13 pm
What is your question?
Chris Tompkins
Video Atlanta LLC
Steve Eisen
Re: mxf files
on Sep 29, 2011 at 1:55:15 pm
Leave your data alone. You want to make an exact copy of your CF/SD card.
This tutorial will explain the exact workflow.
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
Re: mxf files
on Sep 29, 2011 at 3:05:08 pm
You willl need to download and install the Canon XF Log and Transfer plugin...
http://software.canon-europe.com/software/0040354.asp?model=
And then use the tutorial posted above.
Shane
Tamsyn Reynolds
Re: mxf files
on Oct 3, 2011 at 11:37:04 am
thank you so much for your response.
I've not made myself clear. The issue is that many of my .MXF files have gone missing out of their folders within the overarching contents folder.
so although the sequence of folders (and my own memory) point to the fact that the video clips were shot, many of the folders are empty.
See the uploaded picture. In the AA00330 folder (for example) there's no MXF file.
i never deleted them, so at a loss as to what could have happened.
