XDCAM transfer glitches audio
Holly Buechel
on Sep 26, 2011 at 5:01:55 pm
Hello all,
I've transferred a few hours of XDCAM footage I received from a client in XDCAM Transfer. (The original file structure wasn't saved so I just have lots of folders with the .MXF and other files. Otherwise, I would have tried this in FCP Log & Transfer.) The files play fine in the preview window of XDCAM Transfer, but when I bring the .mov into FCP, the audio is crazy and glitchy. It's making it impossible for me to sync with Pluraleyes to my 2 other DSLR cameras and external audio files. I have the latest version of XDCAM Transfer and tried doing one file at a time, but still glitchy. The picture is fine, but I can't sync or use the audio.
I'm on FCP 7.0.3 and I'm using a MacBook Pro 2.6GHz Intel, 4GB RAM, on Mac OS X 10.6.8.
Any ideas?
mahboob ekp
Re: XDCAM transfer glitches audio
on Sep 26, 2011 at 6:53:00 pm
whats your playback settings and your sequence settings?
Holly Buechel
on Sep 26, 2011 at 7:06:16 pm
I set the sequence to match the footage.
1920 x 1080 HDTV 1080i (16:9)
Square
23.98
Compressor: XDCAM HD422 1080p24 (50MB/s)
Audio: 48 kHz
24-bit
I can play the clips outside of FCP and they sound fine so it's something going on with FCP.
Holly Buechel
on Sep 27, 2011 at 8:06:07 pm
So I found a temporary solution to this issue.
To completely avoid using XDCAM in FCP, I transcoded the footage to Apple Pro Res (LT) (because that's what my DSLR footage is) and now I have my sound back in sync and it integrates into my project even better than before. The only losses I had were time, some quality, and hard drive space. So until this bug, or whatever this problem is, get's figured out, better luck transcoding.
Joey Everington
on Oct 25, 2011 at 12:05:42 pm
This a dumb question, but how were able to transcode the footage?
Joey Everington
on Oct 27, 2011 at 4:50:41 pm
Or better yet, what do you use to transcode your footage?
