Open DML Motion JPEG 30fps 640 x 480 conversion to pal 25fps?
John Mäkinen
on Sep 24, 2011 at 10:35:27 pm
I am working with FCP 6.0.6.
Mac 10.4.11
2.16 GHz Intel 2 Duo
2 Gt 667 MHz DDR2 SDRAM
I´ve tried the MPEG Streamclip and can´t find the solution for a smooth conversion. My project is in dv-pal 720 x 576 25fps. Is this conversion possible?
Thank you for any help.
Rafael Amador
Re: Open DML Motion JPEG 30fps 640 x 480 conversion to pal 25fps?
on Sep 25, 2011 at 10:19:32 am
Try Compressor, setting the Frame Control ON.
Be careful with the field order of your MJPEG
Even if your project is DV, export to Prores.
rafael
http://www.nagavideo.com
John Mäkinen
on Sep 25, 2011 at 2:04:41 pm
Thanks Rafael!
I don´t really know how to use compressor - is there a ready made setup I could use?
Rafael Amador
on Sep 25, 2011 at 5:21:43 pm
There are presets for Standard Conversion. Chose Prores/PAL.
You will need to set the Frame Control manually.
rafael
John Mäkinen
on Sep 25, 2011 at 6:37:13 pm
Thank you very much!
I will try that.
John Mäkinen
on Sep 26, 2011 at 11:48:04 pm
Rafael,
It worked great!
Thanks super!
John
