Any way to adjust all keyframes in an audio layer with a single attribute such as lowering or raising levels?
Colin Marshall
on Sep 21, 2011 at 6:25:55 am
I made a ton of adjustments to an audio track on my sequence, but just realized I need to raise the entire thing by a few dBs. Is there any way to raise all my keyframes at once by the same amount? Thanks CC!
Bret Williams
Re: Any way to adjust all keyframes in an audio layer with a single attribute such as lowering or raising levels?
on Sep 21, 2011 at 12:45:47 pm
Look under the modify menu for "levels." Learn that hot key. It is your best friend. cmd+opt+L
