Canon 600D and FCP 7
Douglas Gentry
on Sep 17, 2011 at 12:24:40 pm
I cannot find the plugin to get the Canon 600D to work with FCP 7 (for log and transfer).
I can do it with footage from the Canon 5D, no problem.
Has anyone had issue with the Canon 600D with log and transfer?
Better still, does anyone know where I can get the 600D plugin for FCP 7?
Andrew Rendell
Re: Canon 600D and FCP 7
on Sep 17, 2011 at 12:56:25 pm
Just thinking out loud here, but if you go to
then follow the link to the 550D hack and see how that's done, you might be able to do the same kind of hack for the 600D.
I've done it for the 550D (and it works fine) but I haven't touched a 600D yet, so I can't advise you to mess with your gear in this way unless you are comfortable with the process.
Ian Lynn
on Oct 29, 2011 at 12:00:20 pm
I also have a problem with 600D footage in FCP Log and Transfer. I think this is because the Canon plugin for FCP is looking for pairs of files, one .mov and one .thm for each clip. Problem is that, unlike earlier Canons, the 600D does not create thumbnail files, so FCP cannot see the movie files.
© 2018 All Rights Reserved
