Syncing problem with multiclips when switching camera angles
Basil Glew-Galloway
on Sep 15, 2011 at 11:20:57 pm
I have multiclips successfully made. When I drop them into my timeline, double-click them, and look at them in the viewer, the two angles are in sync. But then when I go to the multiclip in my timeline and switch camera angles, the video for the other angle is way off, a whole different part of the interview. The more times I switch back and forth, the further the clip migrates from the original cut.
Any thoughts here?
-b
FCP 6.0.6, Mac OS X 10.6.8, 2 x 2.4 Quad-Core Intel Xeon, 8 GB DDR3 RAM
Jerry Hofmann
Re: Syncing problem with multiclips when switching camera angles
on Sep 18, 2011 at 5:15:06 pm
Post the format of the source video files and the sequence settings you're using.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
