Purple Line Running Down the Right Side of my Footage
Brien Longobardi
on Sep 15, 2011 at 8:02:02 pm
Hey Guys; Has anybody ever had a purple line running down the right side of your footage? OK here is what's going on I am working on a feature documentary some footage HD and some SD I took the SD footage and converted the footage to DVCPro HD 960x720 in Compressor. Some of the tapes / video file has a purple line running down the right side of footage in the source and timeline window but when I look at the orginal file it is fine. I also notice that the composition is off from when it is in the source window compared to the orginal it looks like it drifted alittle left so I went to the motion tab in the source window and on the X-axis parameter typed in 1 and it is gone and the original and the source window are an identical match. Any help would be highly appreciated and thanks in advance
Brien
Jerry Hofmann
Re: Purple Line Running Down the Right Side of my Footage
on Sep 18, 2011 at 5:17:51 pm
Sounds like some sort of rounding error in the resize. I think if it looks OK otherwise, I'd crop it out and move along...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Brien Longobardi
on Sep 19, 2011 at 12:22:21 am
That was my thought I just wanted to double check. Thank you for your response
B
