Skipped frames when exporting
David Fortin
on Sep 15, 2011 at 7:56:50 pm
FCP 7.0.3
OS X 10.6.7
Sequence XDCAM EX 1080 30p (35 Mpbs/VRB)
I have a nest at the end of my program that includes a video on V1, and PNG files on V2 > V5.
When I watch the video (frame by frame) it is constant.
When export to QuickTime, the video skips a frame (or 2 - not sure).
The program is 3:30 long and this happens in the last 10 seconds.
When I just export the end, it still happens, but not in the same place.
I've never had this happen before. The video is a Stock Footage clip that was JPEG format. I converted it to PRO RES to edit.
Has anyone else experienced something like this?
Any suggestions on solving the problem.
I repaired permissions, trashed preferences, shut down and rebooted.
**** I just tried converting the footage to XDCAM HD 1080p.
I replaced the PRO RES version with this one and it seems to work.
Still wondering if anyone else has ever seen this.
David
Dave LaRonde
Re: Skipped frames when exporting
on Sep 15, 2011 at 8:25:55 pm
Nested sequences have never performed as advertised in FCP. If you can undo the nesting, I bet you'll be a lot better off. Delete the nested sequence from the main sequence, copy the contents of the nested sequence, and paste it into the main sequence.
Dave LaRonde
Sr. Promotion Producer
