FCP does not save the capture fully
Rasikacarya Das
on Sep 15, 2011 at 12:35:39 pm
It appears that fcp is capturing properly but at the end of the tape when verified the size of the capture, it shows much less than expected. For example it would be around 4 to 6 GB instead of around 13 GB per DV.
Machine/Software Specifications: Mac OS X 10.6.8 with 2GZ Intel CORE DUO, FCP 7
Can anyone help me out !
Jerry Hofmann
Re: FCP does not save the capture fully
on Sep 18, 2011 at 5:19:15 pm
What format are you capturing? DV?
Jerry
Rasikacarya Das
on Sep 19, 2011 at 9:05:37 am
We are using HDV 1080i50 format. But we have seen the same problem with DV also.
But, now we have discovered the problem and the solution.
Recently we have added a new Hard disk which was formatted in FAT32(windows format) and because it allows only 4 GB file size we were having problems. Now we have re-formatted this hard drive using the format Mac OS Extended (Journaled) and the problem is resolved.
Anyways, thank you Jerry for your response.
