Importing xml into FCP 7.0.3 gets "critical error"
Mads Astrup
on Sep 14, 2011 at 10:11:04 pm
I am trying to import a sequence xml files with subtitles into my FCP 7.0.3.
I got the file from a professional translation company. First of two files worked fine. The second was aborted due to "critical error".
Do anybody has a way too solve the problem?
Thx, MADS
Shane Ross
Re: Importing xml into FCP 7.0.3 gets "critical error"
on Sep 14, 2011 at 10:51:43 pm
Have them redo the third one and send again. Might have been an issue in the creation of that particular XML.
Shane
Mads Astrup
on Sep 15, 2011 at 6:19:54 am
Hi Shane,
I already did that, and it still does not work. Other suggestions?
Shane Ross
on Sep 15, 2011 at 4:26:33 pm
Send as a different XML version? Instead of V5, how about v4? v3?
Shane
Anders Teigen
on Sep 15, 2011 at 6:44:44 pm
Hi!
If you work in a Norwegian setting, some applications can create problems in the XML if there are character encoding mismatch. Characters like Æ, Ø and Å can be misinterperated if encoded otherwise, and create faulty XMLs. The character encoding should be UTF-8 through the whole workflow. Start by checking the first lines in the xml (read in a text editor) and look for "encoding". Then check if there are language preferences in the subtitle generator.
There can also be isues with other special characters sneeking in to the subtitles.
regards
-anders
Mads Astrup
on Sep 16, 2011 at 8:28:08 am
Hi Shane and Anders,
The company ended up sending six different files, and in the end it worked. Don't know why.
@ Anders - the text was in english.
Thx for taking your time.
Regards Mads
Anders Teigen
on Sep 16, 2011 at 7:13:57 pm
Good to hear! Thanks for the update.
