What are the Lowest Possible Export (Compression) Settings??
Anthony Gerace
on Sep 14, 2011 at 8:27:56 pm
I want to export as quickly as possible. Video Quality is not an issue at the moment, I just want to export my full HD timeline into a quicktime file as quickly as possible so I can log the footage. WHat compression settings should I use to do so?
Chris Tompkins
Re: Lowest Possible Export (Compression) Settings
on Sep 14, 2011 at 8:43:07 pm
Are you just viewing it on your comp?
What do you mean by "log" the footage?
File ~ Export - bam! Done in 2 sec.
Export using "Current Settings".
Chris Tompkins
Video Atlanta LLC
