is it possible to change data rate in FCE?
Robert Wilkins
on Sep 14, 2011 at 3:36:43 am
I imported two different clips from 2 camacorders. The bit rates are off so they don't line up on the frame edges. Is there anything I can do sync the clips within a frame or change the data rates so they'll be able to sync?
Bob
R.Wilkins
Michael Gissing
Re: is it possible to change data rate in FCE?
on Sep 14, 2011 at 4:10:40 am
Perhaps some more info. What codec, frame size and frame rate are the two clips and what are your sequence settings?
I don't understand what you could mean by frames not lining up because of bit rate so I suspect you have different frame rates which is a bad idea and needs fixing.
