Workflow for AVCHD 3D Files using Quicktime and Final Cut Pro.
dave divehall
on Sep 13, 2011 at 9:22:43 am
Hello,
I have been given some AVCHD 3D files which i need to convert to Quicktime and edit with.
I have never worked with this before, so any help on how i can convert both Left and Right files into a quicktime and what the work flow for editing these with Final Cut Pro is would be much appreciated.
Thanks in advance :-)
Steve Eisen
Re: Workflow for AVCHD 3D Files using Quicktime and Final Cut Pro.
on Sep 13, 2011 at 1:12:59 pm
Before you dive into your project, you will need to learn the proper tapeless media workflow.
Start with Shane Ross' tutorial.
Hint: There is a tab above.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Everest Mokaeff
on Sep 13, 2011 at 2:16:57 pm
To work with left/right camera in FCP7 you'll have to use either stereo3d toolbox plugin or Neo3d. Both apps are commercially available. Before you start I strongly suggest you to take your time and read as much as you can in regard of stereo film production. Otherwise you risk end up with technically-impaired movie.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
dave divehall
on Sep 13, 2011 at 11:38:43 pm
Great, will do.
Thanks for the help guys.
Katherine Sweetman
on Jan 27, 2012 at 6:36:03 pm
If one wanted to split the AVCHD 3D into Left Right has anyone found easy/cheap way to do this on Mac and obtain FCP compatible Left Right videos?
