Text changes size when I compress
Dan Herz
on Sep 12, 2011 at 4:00:37 pm
I am editing a 720p project in FCP (960x720). I am adding lower third graphics to ID people being interviewed. When I compress in Compressor, the video looks great, the lower third grapic looks great, but the text, which I created in FCP, changes in size and seemingly, aspect ratio...and does not fit in the lower third graphic. I do not see anywhere to adjust the text graphic aspect ratio in FCP...and I have never had this happen before. I have tried several times wwith the same result. I am not sure if this is something I need to fix in FCP or in Compressor. Any ideas?
David Roth Weiss
Re: Text changes size when I compress
on Sep 12, 2011 at 8:43:58 pm
Try exporting as a self contained QT first using Export>>Quicktime Movie, then use that file in Compressor as your "master" to make whatever additional encodes you require.
Good luck...
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Producing Episodic TV with "24" Producer Michael Klick:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-1_Michael-Kl...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Dan Herz
on Sep 12, 2011 at 11:33:22 pm
That worked...thanks!
Strange that you have to do that to make it all work.
