Exporting to Quicktime gives me a file with a .mov-1 extension
Luis Megid
on Sep 11, 2011 at 12:35:49 am
I never had this problem in FCP, but yesterday when I exported the video to Quicktime, instead of a .mov extension I got a .mov-1.
The file behaved normally when I FTPed it, but it was hard to find in the destination.
Anybody knows why I would get the .mov-1 extension in the first place? Thanks.
Dave LaRonde
Re: Exporting to Quicktime gives me a file with a .mov-1 extension
on Sep 11, 2011 at 2:05:45 am
[Luis Megid] "Anybody knows why I would get the .mov-1 extension in the first place? Thanks."
You must have exported using quicktime conversion, and it used the most recent settings. Just change the settings. It's dead simple.
Dave LaRonde
Sr. Promotion Producer
Luis Megid
on Sep 11, 2011 at 2:45:42 am
Thank you Dave. I will try it. Any reason why the Quicktime conversion settings may have changed? I always used the same procedure and this never happened.
Dave LaRonde
on Sep 11, 2011 at 3:16:09 am
Somebody must have used your machine without your knowledge.
Dave LaRonde
Michael Gissing
on Sep 11, 2011 at 8:37:16 am
That looks to me like file spanning. Did you export to a FAT32 drive? With FAT32 a file cannot be bigger than 4 gig so a larger file will span over a few clips with -1, -2 etc to indicate it is a spanned multi file. In quicktime it will play as one file but beware as all parts need to be in the same folder to play as one file.
