Trouble with HD video and widescreen
William Wasson
on Sep 10, 2011 at 11:54:15 am
I'm working with HD video 1440x1080. In the viewer it fills the screen but when i place it on the timeline it becomes widescreen with black bars. I've tried adjusting the sequence settings with bad results. I've worked with this type of video before with no problems, what am i doing wrong?
John Pale
Re: Trouble with HD video and widescreen
on Sep 10, 2011 at 3:05:23 pm
That is most likely an HDV clip. Did you try an Easy Setup for HDV ?
Don't set everything manually. Use an Easy Setup.
William Wasson
on Sep 10, 2011 at 11:06:21 pm
thanks i got it to work!
