1080p to 2K & Final cut workflow
Areful Eeslam
on Sep 10, 2011 at 7:44:49 am
I dont know if anybody here tried it, but im thinking of upscaling 1920X1080p footage up to 2K resolution for FILM (negative) transfer. I think upscaling to 4K would be choppy, if anyone has experience about this kindly mention. I need to know the final cut studio & other necessary program workflow (edit, cgi, dpx upscale, xml, color grade & final output).
Please enlighten with me guys...
Areful Eeslam
Filmmaker
Shane Ross
Re: 1080p to 2K & Final cut workflow
on Sep 10, 2011 at 8:39:13 am
Find a company that does the film out, and ask them.
Shane
Areful Eeslam
on Sep 10, 2011 at 8:46:01 am
Thanks for your suggestion, but the thing is i live in Bangladesh & we just got a film transfer machine here, we are about to do some test, but i wanted to know about the post workflow before doing so. I need know what im doing is right method, cause this stuff is expensive (negative), cant effort to retesting again & again.
Eagerly waiting for some response
Regards.
Rafael Amador
on Sep 11, 2011 at 10:26:43 am
[Areful Eeslam] "but the thing is i live in Bangladesh"
You are right beside India.
If I'm not wrong, probably the best place in the world to get affordable 35mm printing.
[Areful Eeslam] "I dont know if anybody here tried it, but im thinking of upscaling 1920X1080p footage up to 2K resolution for FILM (negative) transfer"
You can get that at home with a KONA.
[Areful Eeslam] " think upscaling to 4K would be choppy,"
What do you mean? On playing the file?
It will be choppy if you play it on a system without enough performance.
You should be able to play 2k from an an eSATA HD through a lap-top.
rafael
http://www.nagavideo.com
Areful Eeslam
on Sep 14, 2011 at 6:53:38 am
[Rafael Amador] You are right beside India. If I'm not wrong, probably the best place in the world to get affordable 35mm printing.
The political & beurocratic problem at two countries' custom makes a good deal of hassle of shipping prints which takes months to get there & come back as well, which eventually makes production delay & cost effective. We are looking for native solution that's why we imported a transfer machine.
[Rafael Amador] You can get that at home with a KONA.
Thanks for the suggestion. Would you be kind enough to specify which KONA would be best for me for grading & 2K upscaling purpose?
About choppy i meant upscaling a 1080p video into 4K transfer, i thought it would be too stretched like upscaling a 480p video onto 1080p, dont you think? not 100% sure though, any suggestions?
Thanks for your reply
Regards.
Rafael Amador
on Sep 14, 2011 at 7:32:25 am
The KONA-3G is the one able to manage 2K.
In the KONA forum you will get help about this device.
rafael
Areful Eeslam
on Sep 15, 2011 at 6:07:26 am
Thanks man.....
