Auto Tune plugin?
David Isser
Auto Tune plugin?
on Sep 8, 2011 at 4:19:47 pm
Anyone know if there's an auto-tune plug in for FCP? or AVID for that matter?
Shane Ross
Re: Auto Tune plugin?
on Sep 8, 2011 at 4:26:31 pm
What is an "auto tune" plugin? What do you want it to do?
Shane
Alan Okey
on Sep 8, 2011 at 5:09:38 pm
[Shane Ross] "What is an "auto tune" plugin? What do you want it to do?"
http://en.wikipedia.org/wiki/Auto-Tune
Excerpt:
"Auto-Tune was used to produce the prominent altered vocal effect on Cher's "Believe", recorded in 1998, the first major hit song to employ the software for this purpose."
Two of the most popular software tools used for autotuning are Antares Autotune and Celemony Melodyne.
Used to great comic effect in the Autotune the News series of viral videos - search YouTube for examples.
Dave LaRonde
on Sep 8, 2011 at 4:30:35 pm
Why do you need a plugin when you can correct audio pitch in Soundtrack Pro?
Dave LaRonde
Sr. Promotion Producer
Drake Hale
on Sep 8, 2011 at 5:05:16 pm
If you have GarageBand which I'm sure you do you can fake the effect quite well in there. Theres a couple of videos on YouTube to take you through the process. The actual company is called Antares and any "true" auto tune plug in would be available through them
"It's all about keyframes"
Anonymous
2011 3.2GHz 27" iMac, Final Cut Studio 2, Adobe CS4
Mark Suszko
on Sep 8, 2011 at 6:17:32 pm
I made this little throw-away piece using the auto-tune emulation technique in Garage Band as has been mentioned. Wasn't very hard to do, and the price was right.
Guy at the end sounds like the organ solo of "What A Lucky man He Was", or some ELP synth solos:-)
Shane Ross
on Sep 8, 2011 at 5:16:00 pm
Wait...is this the David Isser I worked with before? The guy who brews his own beer?
Shane
David Isser
on Sep 8, 2011 at 7:26:28 pm
The one only, and certainly the only one who's an editor... yes.
Wasn't looking to do anything specific, just was curious if anyone was developing a plugin that could be used in the timeline. I've seen the garage band one, how do you do it soundtrack pro?
Dave LaRonde
on Sep 8, 2011 at 7:36:42 pm
Okay, so when you brew do you mash or do you use extracts & specialty grains?
When I've used Soundtrack Pro to change pitch, I've just done arithmetic to raise/lower by the proper amount, and it's turned out well. But then, my needs are typically simple. I'm not trying to match the pitch of an off-speed turntable or anything.
Dave LaRonde
David Isser
on Sep 8, 2011 at 8:07:12 pm
hmm, sounds like I'll just have to play around with it one of those rare free moments.
I use extract, but only because I don't have a mash ton. one day it'll be beside the kegerator in my garage turned brewery...
Scott Sheriff
on Sep 8, 2011 at 9:04:31 pm
For STP, or GB any autotune plugin that is AU will work. Antares has one, but there are others if you poke around. GB has a basic autotune like function built into it.
Scott Sheriff
Director
http://www.sstdigitalmedia.com
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." ---Red Adair
Where were you on 6/21?
