Cannot get clip and sequence settings to match in ProRes/ Clips show up unrendered (red) regardless of sequence settings
mike urdaneta
on Sep 7, 2011 at 11:22:33 pm
Hello,
I have been trying different things with this footage for what seems like forever, I'll give a quick rundown and then some more details:
The clips have been sent through a few different conversions (CONVAR recovery, DIVFixx++, and/or Mpeg streamclip or Compressor).
At the moment they are all as follows:
creator: quicktime player
frame size: 320x240
compressor: Apple ProRes 442(HQ)
pixel aspect: Square
field dominance: none
aud format: 32-bit floating point
The only piece of information that varies between the clips is the framerate, which is generally 12fps or 20fps, but I have seen a few with 8fps and 13fps.
The sequence settings that FCP wanted to adopt when I first dropped a clip into the timeline were:
frame size: 1280x720 HDTV720p (16:9)
editing timebase: 29.97
compressor: HDC720p30
audio: 48k
I have tried many different variations of frame sizes and compressors. 320x240 seems to zoom into the image quite a bit, while nothing else I have put into the compressor setting has even come close to the frame rate.
I just suffered a system crash, so while my files are intact, I had to reinstall FCP and I am no longer getting a suggestion for sequence settings when I drop a clip into the new sequence.
I have moved FCP's settings out of the library>application support folder and reset the PRAM.
More details:
FCP version 6.0.5
Mac OS X 10.5.8
MacPro3,1 Quad-Core Intel Xeon 2.8ghz
Footage from Tiger VCAMNOW v1.0 shows up in original format as:
creator: VLC
vid rate: 7.00 fps
frame size: 320x240
compressor: Apple OpenDML JPEG
pixel aspect: square
Before everyone goes crazy about not being able to use footage from this camera, I did so years ago with just one run of compressor for each clip. I unfortunately do not remember to what i converted it. I assumed ProRes would work best, but apparently not.
The clips as are tend to lose a percentage of the end of the clip when converted through compressor or just dropped into the timeline, and for some reason Mpeg streamclip was better with this.
As a side note, we don't care about the audio.
Any help that anyone can give is greatly appreciated, I have seen similar posts, but have not been able to resolve the issue. I am not a noob to editing, but all of this conversion stuff is a bit over my head.
Thank you in advance.
Shane Ross
Re: Cannot get clip and sequence settings to match in ProRes/ Clips show up unrendered (red) regardless of sequence settings
on Sep 7, 2011 at 11:48:03 pm
[mike urdaneta] "frame size: 320x240 compressor: Apple ProRes 442(HQ)
That isn't a standard size. Those are in fact very small dimensions. FCP doesn't work with any frame size converted to ProRes, it has to be a broadcast dimension...
720x486
1280x720
1920x1080
What recording device are you using?
[mike urdaneta] "Footage from Tiger VCAMNOW v1.0 "
That's some odd toy camera. Doesn't shoot a format that is editable. Mainly designed for just playback I think.
Shane
