Final Cut Sequence Settings for Blu Ray Slide Show
david mayer
on Sep 2, 2011 at 5:06:24 pm
I will be making a Blu Ray slide show with high resolution TIFF files and music. I have found a lot of info on the best Compressor settings for creating the Blu Ray file, but less on the Final Cut settings. What is my best bet for the sequence settings in the Final Cut timeline?
Dave
iMac 2.8 GHz Intel Core i7, 8 GB
OS 10.6.2
Final Cut Pro 7.0
Jerry Hofmann
Re: Final Cut Sequence Settings for Blu Ray Slide Show
on Sep 2, 2011 at 9:33:35 pm
1080 ProRes 422 or LT most likely... 29.97 if in the US... 25fps if in PAL land...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Steve Eisen
on Sep 3, 2011 at 5:20:53 am
Check out Gee Three's PhotoMotion. It saves a lot of time when creating slide shows.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
david mayer
on Sep 3, 2011 at 1:05:17 pm
Thanks much, Jerry and Steve.
Dave
OS 10.6.2
Final Cut Pro 7.0
david mayer
on Sep 3, 2011 at 1:40:42 pm
Jerry,
How does this look for the Sequence Settings?
Frame Size 1920 x 1080
Aspect Ratio HDTV 1080i (16:9)
Pixel Aspect Ratio HD (1280 x 1080)
Compressor Apple ProRes 422 (HQ)
OS 10.6.2
Final Cut Pro 7.0
Jerry Hofmann
on Sep 3, 2011 at 2:43:50 pm
The pixel aspect ratio isn't right... should be square...
Just load the "sequence preset for ProRes HQ 1080... 30p might be just the ticket for a slide show too.
Current DVD:
Steve Eisen
on Sep 3, 2011 at 5:55:01 pm
Keep in mind using ProRes HQ will yield very large render files.
Steve Eisen
Vice President
david mayer
on Sep 3, 2011 at 9:55:59 pm
will do
OS 10.6.2
Final Cut Pro 7.0
david mayer
on Sep 3, 2011 at 10:08:25 pm
Jerry,
There is no preset with that exact name.
Would it be this one?
Preset is called: ProRes 422 (HQ) 1920x1080 30p 48 kHz
and results in the sequence menu showing an aspect ratio of: HDTV 1080i (16:9)
Thanks again,
Dave
OS 10.6.2
Final Cut Pro 7.0
Jerry Hofmann
on Sep 3, 2011 at 11:01:47 pm
That will work...
Jerry
Current DVD:
david mayer
on Sep 4, 2011 at 12:53:19 am
great
OS 10.6.2
Final Cut Pro 7.0
Rafael Amador
on Sep 4, 2011 at 12:20:00 am
[david mayer] "
and results in the sequence menu showing an aspect ratio of: HDTV 1080i (16:9)"
I would change the sequence to Progressive (NONE).
You are working with stills. No interlacing involved.
rafael
http://www.nagavideo.com
david mayer
on Sep 4, 2011 at 12:56:31 am
That brings up an interesting point.
The Blu Ray DVD will have 2 chapters - the 8 minute stills
montage and a 3-minute HDV interview.
I was going to build them in the same sequence
so I could create a single file to burn to Blu Ray disk.
So I guess the choices are to compromise the montage,
or compromise the interview, or build them in two
sequences. What do you think?
OS 10.6.2
Final Cut Pro 7.0
Jerry Hofmann
on Sep 4, 2011 at 3:44:20 am
I'd capture the HDV as ProRes... make it match the sequence setting. So likely it should be 1080i 29.97. Then it would be all the same format.
Jerry
Current DVD:
david mayer
on Sep 4, 2011 at 1:50:25 pm
makes sense
I only was not sure what Rafael meant about "Progressive" (not interlaced)
did not see a box for that in the sequence settings
OS 10.6.2
Final Cut Pro 7.0
Jerry Hofmann
on Sep 4, 2011 at 2:02:46 pm
Don't think there is one... but 30p, 24p are Progressive... it's what the "p" stands for. But if you're mixing the HDV with it, be sure that the HDV is progressively shot... it likely isn't. So if the images and the video are in the SAME sequence, it shouldn't be progressive. If they are in different sequences, use interlaced video for the interlaced HDV you have, and progressive for the stills.
Jerry
Current DVD:
david mayer
on Sep 4, 2011 at 3:04:13 pm
again, this makes sense
so... do you think the photo montage section of the Blu Ray disk
will suffer in any noticeable way for not being edited in a
"progressive" sequence?
thanks again - very helpful
OS 10.6.2
Final Cut Pro 7.0
david mayer
on Sep 5, 2011 at 2:42:23 pm
OK - I'm going with an interlaced sequence for the montage
and the HDV interview - so will all of the still pictures look
better if I de-interlace them?
OS 10.6.2
Final Cut Pro 7.0
david mayer
on Sep 5, 2011 at 4:27:40 pm
Sorry to pile on the posts, but a bigger problem
just took over.
"Out of memory" error message while rendering. Will
not let me render.
I'm wondering if it has to do with my sequence settings.
The sequence preset gave me:
Pixel Aspect Ratio Square
Field Dominance None
Compressor ProRes 422 (HQ)
OS 10.6.2
Final Cut Pro 7.0
david mayer
on Sep 5, 2011 at 10:13:13 pm
For what it's worth - I solved it
by using the H. 264 compressor in the
sequence settings.
OS 10.6.2
Final Cut Pro 7.0
